Our Indesit fridge recently had its thermostat replaced, and ever since, it makes an irregular chattering noise when the compressor runs - sounds a bit like something is hitting styrafoam inside the body somewhere. Any clues?
If the thermostat wasn't properly anchored into place, the vibration can cause it to rattle on a panel.
Thanks, Kevin
is it anchored other than at the main housing in the front? i.e. is the metal coil also anchored somewhere? and how would i get at it? Ron H |
That depends on the exact model. If the thermostat was just replaced though you should have a service warranty on the work performed. Maybe rattling in the control compartment where it is housed.
| MAH8700AWW Tapping noise during spin | jwolfe | Maytag/Magic Chef/Admiral/Jenn-Air | 1 | May 13th, 2007 08:33 AM |
| UltraWash 665.15835793 Noise & Not Circulating Water | Echous | Sears Kenmore | 4 | August 26th, 2006 10:19 AM |
| New Freezer Noise (253.26762100)- Need Repair? | TigardUser | Sears Kenmore | 2 | June 17th, 2006 10:46 PM |
| Kenmore 580.74054400 Coolant noise | MetalCastr | Window & Room Air Conditioners | 2 | May 6th, 2006 11:10 AM |
| High pitched whining noise Kenmore refridge | wat4 | Sears Kenmore | 5 | April 9th, 2006 04:09 PM |
