I work on many Sub Zeros and have always been able to diagnose and repair any problem I have run into. This model is a old RFD361, in great shape for the age. I have worked on this refrigerator a few years back for this customer. This model uses a single compressor to refrigerate both sides. Customer complaint was freezer @7 fridge @ 45 degrees. All fan motors were running, no defrost problem, clean condenser, lights going off when door closed. I put my gauges on it and have a back pressure of 10 psi, a head of 150psi. Cut out is 2 psi cut in 15 psi. So I figure the compressor is a weak.
I installed a new compressor and changed refrigerant to 134A. Customer calls back says temp are about the same. I go back and have a back pressure of 5 head 150 ish. To confirm enough refrigerant, I looked at both evap coils and they are fully frosted by a thin film of frost, normal frost. And oh yea, the ice maker was not stuck in harvest So the compressor is fine, stat , defrost working OK, all fan motors good, and confirmed no electric heaters of any kind on while in refrigeration. Can you guess what it was? I never ran into this problem but I got it fixed. A hint: when I unplugged freezer fan, the fridge temp went down. No air leak problem either, door gaskets and cabinet seal good.
http://www.dependable-refrigeration.com |
Sounds suspicious to me.
Did you confirm the temps with your own thermometer? Or is it possible the customer is using an uncalibrated thermometer? |
You state that refrigerator temperature started dropping when you stopped the evaporator fan which would lead to an air flow problem.
| Amana side-by-side is off, but fridge light is on and cool air blows from the side. | axeman61 | Amana | 24 | September 12th, 2008 03:41 PM |
| Kenmore Bottom-Freezer Fridge Icing up in Drainpan | Hondatudinal | Sears Kenmore | 3 | September 18th, 2007 08:46 PM |
| Kenmore Coldspot freezer perfect, fridge warm | nandof | Sears Kenmore | 2 | July 1st, 2007 10:49 AM |
| GE fridge not to cold and making gurgling noises and shuts off when moved. | oopsydaisy | GE/Hotpoint | 3 | April 26th, 2007 11:27 AM |
| Jennair fridge side not cold after defrost | wobbletop | Maytag/Magic Chef/Admiral/Jenn-Air | 7 | September 20th, 2006 01:48 AM |
