I have a 3 yr old Samsung Refrigerator RS2644SL. The digital temp is blinking and is now making a noise (sounds like like the blower fan) that stops when I open the door. A month ago the Thermo-fuse and sensor was replaced by a repair company because the digital temp was blinking, but not making this noise. Is it possible the blower has a bad bearing? Or is now rubbing something after repair? Thank you in advance
I took the access panel off on the inside and found the Case Motor to be bad. Stamped on the plate holding the motor is this description and part #: DA61-00417 [ABS] CASE-MOTOR C.S-2. I tried to order the part from the "Repair Clinic" but was unable to find a match. Can you help locate this part? Thank you
Thank you. I thought it would come as the assembly, this is even better
Glad to help.
| Kenmore freezer Compressor making chirping noise | 56servi | Sears Kenmore | 1 | July 20th, 2008 09:17 PM |
| Refrigerator was making alot of noise & now not cooling | South Texas | Maytag/Magic Chef/Admiral/Jenn-Air | 7 | August 30th, 2007 10:43 AM |
| LG LDS5811 Dishwasher Pump Now Making Horrible Noise | jsevinsk | Dishwashers | 1 | November 21st, 2006 08:01 PM |
