Old April 1st, 2009, 10:18 AM
Triple BB is on a distinguished road
Default Woods Freezer frosting up
Jake, I have a Woods manual defrost upright 16.9 cu ft freezer, model V17WUA. Sorry for posting under this manufacturer name, but I didn't see anything for Woods or when I searched the forums on this issue. Questions is, I spent 4 hours chipping and defrosting large chunks of ice out of this freezer last Sunday. It seems like the thing always frosts up at a fast rate. Today I see a 1/2" of new frost buildup in places where I just cleaned it. Anything I can do to slow down how fast this feezer frosts up. My other freezer is also a manual defrost and I rarely have to clean it out. Thanks.
Old April 1st, 2009, 10:53 AM
It sounds like you have an air leak causing condensation to form more on your evaporator coils, thus more frost faster.
Check all around your door gasket seal for leaks or a torn gasket.
Old April 1st, 2009, 01:56 PM
Thanks Jake. Appreciate the help...
Old April 1st, 2009, 03:20 PM
Ok, let us know the outcome.
Old July 21st, 2009, 11:46 PM
Jake, just wondering if you can help a bit more on my freeze up issue. I can't see that the gasket is torn nor can I tell where it might be leaking. Should I be able to feel cold somewhere around the gasket if its the culprit. Also, I've been trying to find a door gasket, but I'm not having much luck. Any suggestions.
Rick
Old July 22nd, 2009, 11:11 PM
Yes Rick, feel all around your door gasket for cold air coming out.
You can order the door gasket through Woods website here:
http://www.wcwood.com/
Old July 23rd, 2009, 05:12 PM
Jake, I can't feel any cold air. However, I noticed on the bottom left, the metal on the left side of the freezer sticks out 3/16" more than the metal plate on the bottom. It looks like a manfucturing defect as everything is flat all the way around the rest of the freezer where the gasket touches the freezer. I tried beating the side plate back, but there wasn't much give. So I took a metal grinder and ground things down to try and get everything on the same plane. I then used some fiberglass reinforced jelly to level everything out. After block sanding it with a 12" block, everything is smooth and flat where the metal pieces butt together. Guess we'll see if that was the issue. Thanks.
Old July 23rd, 2009, 08:22 PM
Ok, good job Rick, hopefully that will take care of it.
# FRS26R4CW3 Freezer doesn’t stay cold vinalexnc Frigidaire/Electrolux 2 November 26th, 2007 02:36 PM
GE Freezer -evap motor fan? redlady4850 GE/Hotpoint 1 November 11th, 2007 01:41 AM
Frigidaire Freezer Frosting cjt Frigidaire/Electrolux 1 August 24th, 2007 10:30 PM
GE Performance Profile freezer leaking and frosting at ice maker outlet bbwlp GE/Hotpoint 3 September 22nd, 2005 08:09 AM
Upright Amana Freezer Frosting up on top shelves icecream is soft homegrownkids Amana 1 July 3rd, 2005 09:46 AM
