Old May 31st, 2009, 11:41 PM
goodeats is on a distinguished road
Default kitchen aid undercounter icemaker
KUIS155HLS0 kitchen aid icemaker
water circulating pump changed out twice but still won`t start. what should I TRY NEXT THE CONTROL BOARD OR WIRING HARNESS OR something else.
would a voltage meter work to see if the wires to the pump are hot?
the reservoir fills with water and compressor starts up
Old June 1st, 2009, 11:51 AM
Hi goodeats,
I've never worked on these under-counter stand-alone ice makers models before, so hopefully another tech. or member that has can assist you.
Old June 1st, 2009, 03:36 PM
wobiii is on a distinguished road
If your pump is not getting power when it should (read the schematic for the time cycle) then you have a control board problem. No power to pump = control. I have never had to change a wiring harness on an ice machine, YET. The new style sends chills down my spine. . .
Old June 1st, 2009, 09:35 PM
Default control board would make the pump powerless?
Would the control board make the pump powerless only.
Everything else seems fine the resevoir fills,compressor starts up, ice cutter heats up etc.
Old June 2nd, 2009, 06:40 PM
Yes. I think the relays on the control board are prone to failure. See this happen often with random components. Usually the pump or the condenser fan.
Old June 2nd, 2009, 06:42 PM
Good eats? Alton Brown is my favorite chief. And in New Orleans, didn't notice that at first. I'm in Mandeville and run calls over here on the north shore.
Old June 2nd, 2009, 09:44 PM
Default I will order a new control board!
before this old pump stopped for good it was making a hard grinding noise which might have led to the control board being damaged. this is the 3rd pump being replaced in 9 years. the chlorinated hard water just eats the guts out of the pumps.
I hope a new board works and will let you know what happens. too bad no company makes an undercounter ice flaker machine. my freezer already makes cubes but plaked ice is great for chewing and daquiris
its time for a replacement when the compressor dies
Kitchen Aid KSRP25FNSS00 icemaker issues wetwistedclay KitchenAid 3 February 28th, 2009 10:51 PM
Kitchen Aid model KSRB25FRBX00 icemaker AZJohn KitchenAid 28 February 20th, 2008 12:06 PM
Kitchen Aid Superba KSRG25FK inoperable trent KitchenAid 7 October 9th, 2007 01:21 AM
Freezer temp changes on Kitchen Aid Superba Pete V KitchenAid 3 April 9th, 2007 12:34 AM
Kitchen Aid carwasher44 Buy, Sell or Trade 0 December 30th, 2006 01:23 AM
