Old June 27th, 2009, 11:24 PM
rick_maclean is on a distinguished road
Question Kelvinator freezer not freezing well
I have an older Kelvinator refridgerator. Model number TSK206DN. This model has the freezer in the top and the fridge in the bottom.
The last few days I noticed that the freezer is not working very well. For example a tray of water for making ice would not freeze up.
There is one shelf in the freezer. The inability to freeze seems to be more of a problem on the shelf than on the bottom.
I recall in a previous situation on another refridgerator the defrost cycle was not happening and so ice was built up. I do not know if this is the problem this time.
I emptied the freezer and removed the ice maker (which is not hooked up to water) then removed the metal panel in the back of the freezer. This was after I had unplugged the fridge for a while but not a really long time. There was no ice on the coils with fins
(I am not sure what you call this but assume it is:
Heat-exchanging pipes - serpentine or coiled set of pipes inside the unit ).
Do you have any suggestions on how I can proceed to diagnose the problem and if I need to change parts what I need to remove to get at the part to change?
Rick
Old June 28th, 2009, 09:26 AM
Hi Rick,
Thats the evaporator coil that its called thats inside your freezer.
If you didn't find any frost build-up on that, then its likely your compressor is starting to wear out and thus causing the lack of cooling.
I awesome this unit is about 15-20 years old?
A new compressor can only be installed by a licensed refrigeration tech. and the cost for the compressor and labor would exceed the price for a new refrigerator.
GE Water Dispenser Line keeps freezing up ... Oxen72 GE/Hotpoint 11 May 15th, 2009 09:16 AM
GE Profile PTS25LHP: stops freezing zebazga GE/Hotpoint 3 February 16th, 2009 11:56 PM
fridg freezing amana br22te dewcool Amana 7 August 4th, 2008 06:32 PM
Kenmore fridge bottom freezing; freezer warm; no water bkmason Sears Kenmore 12 May 28th, 2007 11:00 AM
GE Side-by-side freezing food in lower refrigerator buffmann GE/Hotpoint 9 November 14th, 2005 08:29 PM
