Old June 30th, 2009, 02:31 PM
Bucky is on a distinguished road
Default Sub Zero 550 Ice Machine Problem
Sub Zero 550 Ice Machine makes ice. Valve opens. Drops Ice cubes. Refills. After two to three days the tray turns into one big block of ice. I also get ice forming above the freezer below the produce bins. In the back and mostly on the right side. It takes a few months for enough ice to form to cause a problem with the bins.
Old August 21st, 2009, 12:56 PM
wobiii is on a distinguished road
The drain line in the refrigerator compartment is most likely blocked up causing water to drip over the back ledge and onto the refrigerator "floor" where it will freeze and cause your bins to not close properly over time.
The ice maker could have a few possibilities. 1 the tube may not be aligned properly, 2 the icemaker could be out of alignment or tilted, 3 the icemaker may be cracked at the fill tube, 4 the icemaker heater could be out of position or acting up or 5 the icemaker could be bad and need to be replaced.
Hope this helps.
Ice Maker problem - ED2JHGXRT00 Rusty1956 Whirlpool 19 December 24th, 2008 04:02 AM
Ice Machine Problem crawling Refrigerators & Freezers 0 November 28th, 2008 08:25 AM
Whirpool Conqest Gold Side by Side Ice Maker Problem tadpole88 Whirlpool 13 September 21st, 2007 12:29 PM
Whirlpool ED22DQ/RQ Ice Maker problem Rich46 Whirlpool 5 September 11th, 2005 10:16 PM
GE ice machine freezing up, not dispensing ice & whines loud geminisix6 GE/Hotpoint 2 April 5th, 2005 04:25 PM
