Old July 21st, 2009, 10:13 AM
texsn95 is on a distinguished road
Question Samsung french door fridge RFG297AARS leaking from bottom
Howdy, great forum! We recently bought a RFG297AARS model that was slightly used. From the beginning, I noticed a small leak onto the bottom tray as the back access panel was off during startup. I didn't think much of it until last week (which is 3 months later) when the entire floor under the fridge and tray is wet. So it's been doing it for awhile, but it's a slow enough leak that evaporates before coming out from under the fridge and I saw while cleaning. I don't think it's still under factory warranty, so are there any obvious things I can check before I call a tech? I have pics of everything also that I can post later. Thanks.
Old July 21st, 2009, 05:28 PM
I don't work on Samsung appliances, but other techs. may and can assist you.
If no one replies, I can refund the $5 Lifetime Membership fee and you can still keep Lifetime Membership status for other appliances you have.
Old July 21st, 2009, 06:01 PM
No problem about a refund regardless Jake, the info I got here helped me fix an old Kenmore washer, so it's all good
Old July 21st, 2009, 10:11 PM
Good photos,
I see the problem, you had sealed system work done on it before you purchased it, they over-charged it with too much freon R-134a.
You'll need to have a tech. come out to remove/recover some freon out of it, so that low side doesn't frost up back to your compressor.
Old July 22nd, 2009, 08:48 AM
Thanks Jake, honestly I never noticed that iced up line
Old July 22nd, 2009, 09:13 PM
Yup, that sounds like where the water is coming from.
Old August 16th, 2009, 10:44 AM
Ok, had a tech come out and evac some refrigerant to where the line wasn't icing up but it was still cooling steadily on the set temps. So that's good to go, but now there's ice developing 1 one side of the pull-out freezer door. Could it be a related problem or is it more likely a problem with the door seal?
Old August 16th, 2009, 01:05 PM
Its more likely the freezer door seal, check all around your freezer door gasket to make sure there are no gaps in it, it should seal good and tight against your freezer cabinet.
Old August 18th, 2009, 07:16 AM
The seal looks to be ok, nice and smooth and it fully engages all around the bottom. It's just kinda funny how I noticed it after the tech came out, but maybe I wasn't paying that much attention before, who knows.
Old August 18th, 2009, 09:08 AM
Ok, not sure what to tell you on this freezer seal issue, just keep your eye on it for now.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/refrigerators-freezers/16127-samsung-french-door-fridge-rfg297aars-leaking-bottom.html
Posted By For Type Date
Refrigerators & Freezers on Appliance Blog Forums | BoardReader This thread Refback September 2nd, 2009 05:17 PM
GE Monogram side by side leaking at bottom right of door? LosGatos GE/Hotpoint 4 May 28th, 2008 07:53 PM
Sears Kenmore Elite Dishwasher 665 Leaking from pin holes in bottom ScottSD Sears Kenmore 1 July 21st, 2007 03:38 AM
Water leaking into bottom - HOW TO FIX! rgraeter Frigidaire/Electrolux 1 July 18th, 2007 10:54 AM
Kenmore (Whirlpool) 665 leaking badly from door bottom tahani Whirlpool 12 September 21st, 2005 05:37 AM
