Old February 20th, 2005, 10:02 AM
gina is on a distinguished road
Post imported post
Hello,
I have a 4 yr. old kenmore side by side model #25351399103. It started to make some strange sounds(humming like a dirty air ionizer). I then noticed that it completely lost cooling and defrosted. I unplugged it for few hours then plugged it back in and within seconds I could hear something like a relay clicking, the compressor did not come on. I shut it off for couple of days , then plugged it back in and I could hear the c ompressor come on and it started to work like normal, cooling properly, however it still made some strange electrical sounds off and on. after running for about a week it stop cooling again, and now it will not restart the compressor even after I left it unplugged a day or so...... it just clicks off a relay I believe.NOt sure if comp[ressor is the issue??? the lights and fan(near coils) are working, but no cooling or sound from compressor or inside fan.
I am also wondering if this has a 5 year warranty?? can not find original papers but the it was mfg. 12/01.
thanks:?:?
Old February 20th, 2005, 12:14 PM
Dan O.'s Avatar
Post imported post
Not sure if compressor is the issue???
By your description it sounds likely to be the compressor or its starting device (relay/overload - see the following link).
LINK > Kenmore 25351399103 Compressor Relay/Overload Asm.
The compressor itself should be warranted for at least 5 years, the labor and service charge might be too. You'd have to check with Sears about that or maybe Jake can say.
If the problem is just the compressor's relay/overload, that part is usually only warranted for 1-year from date of purchase.
JFYI
Dan O.
Appliance411.com
=D~~~~~~
Old February 20th, 2005, 02:36 PM
Post imported post
thanks for the info., I will check the link you sent and go from there..take care.
Old February 20th, 2005, 03:27 PM
Post imported post
Hello again,
Just wondering if you think it is worth ordering the relay and installing,($27.00) I know I can do it. in your opinion /experience would you go ahead with relay r/r. the compressor shows no signs of leaks or bad solder etc.... and it did cool perfectly in between down time....
thanks
Old February 20th, 2005, 09:40 PM
Post imported post
Hi, the 253 model is aKenmore made by Frigidaire, The compressor clicking on this is usually a bad compressor.
The 106 model is a Kenmore made by Whirlpool, and the clicking on this is usually a bad relay.
The way you check a relay is to get a OHM meter to ohm out the start and run terminals in the relay, if there is continuity, then the relay is good.
You should have the 5 year warranty on compressor and labor.
Old March 2nd, 2005, 07:43 PM
Post imported post
thanks Jake, you are correct , the compressor was confirmed to be bad by the sears service tech.they are installing a new one tomorrow......
take care
thanks.
Old March 3rd, 2005, 01:36 PM
Post imported post
Your Welcome Gina!
Have a good day!
253 not adequately cooling Gene Sears Kenmore 5 February 15th, 2007 08:55 PM
Jenn-Air JCD2389DES stopped cooling Palladian Maytag/Magic Chef/Admiral/Jenn-Air 3 September 8th, 2006 01:42 PM
Maytag MSD2456GE Quit Cooling then... Alf50990 Maytag/Magic Chef/Admiral/Jenn-Air 11 March 27th, 2006 12:39 AM
Frigidaire FRS23H5AB9 not cooling rpg4rico2 Frigidaire/Electrolux 3 September 17th, 2005 08:29 AM
