Page 2 of 37 FirstFirst 123412 ... LastLast
Results 11 to 20 of 370
Thread: Kenmore & Whirlpool Ice Maker LED Blinking Codes
  1. #11
    Silver03 is offline Member
    Apr 2006
    Colorado
    I am having the same issue listed previously, however, the LED is not working on either side of the freezer. Do I just need to replace the boards provided at the beginning of this thread? Thanks for the help. Or could it be something else since neither side is working?
    Shawn
  2. #12
    a10acboy is offline Member
    Feb 2006
    Texas
    Default Silver03
    When I tested my LEDs, sometimes they would blink once, sometimes not at all. I unplugged my refrigerator, plugged it back in and then checked the led, and this was the only way I could ever see an LED lit up. I think it's a safe bet to replace the boards.
    Nelson
  3. #13
    Quote Originally Posted by Silver03
    Shawn
    Yes, sounds like yours is completely dead.
    Quote Originally Posted by a10acboy
    Nelson
    Yes, it sounds like it, what position are the ice maker ejector blades at?
    Feb 2006
    Texas
    Hi Jake,
    I was replying to Silver03. I replcaced my boards about a month ago and all is well.
    Nelson
  6. #16
    Opps, sorry Its been a long day.
    Apr 2006
    Colorado
    Quote Originally Posted by Jake
    Thanks for the reply! Do you mean it sounds like the emitter and reciever boards are dead or a more major component is dead? Thanks again for the help.
    Shawn
  8. #18
    Just the emitter and reciever boards.
    rj3
    rj3 is offline Member
    Apr 2006
    cleveland
    I've read this thread and checked my LED code. My optics appear to be working, that is, when the flapper is closed, the LED is on steady. So, if the optics are good, but the ice maker doesn't work, but the water dispenser is working, is the likely culprit a frozen feeder tube I read about in another thread?
    Thanks.
  10. #20
    Quote Originally Posted by rj3
    Thanks.
    Yes, thats possible. Does your Ice Maker sit in the very front top of the freezer? If so, look above the ice maker, you should see a black rubber tube that comes down from the freezer ceiling, check to see if ice is clogging that.
  1. Whirlpool Cabrio UL & F51 Error Codes
    By VJH1968 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: April 13th, 2013, 11:31 AM
  2. Replies: 4
    Last Post: September 18th, 2012, 09:25 AM
  3. kenmore Ice maker not working--red light blinking
    By sard in forum Sears Kenmore
    Last Post: October 22nd, 2011, 12:29 PM
  4. kENMORE hE4T Codes / WHirlpool Duet Error Codes Link & f02
    By Tryspammingme in forum Sears Kenmore
    Last Post: April 30th, 2006, 10:00 AM
  5. Whirlpool Double Oven - E6 F2 Codes
    By Sarge in forum Whirlpool/Roper
    Last Post: April 16th, 2006, 01:20 AM
