Page 3 of 37 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 370
Thread: Kenmore & Whirlpool Ice Maker LED Blinking Codes
  1. #21
    DougB is offline Member
    Feb 2006
    Ohio
    Question
    I'm a bit confused on the LED light for the type 2 ice maker... I am led to believe that the led is suppose to be on all the time for the ice maker to work?! Yet my KA being the same model has never had the LED to be "on" and everything has been working fine since purchased 5 years ago. So does the LED just act up when something is "wrong" by sending blinking codes or is my LED not doing what it's suppose to do?
  2. #22
    Haha, you are lucky Doug, Yours seems to be still working good with no LED coming on. If you see if start acting up, you will need to order the P.C. Board kit, emitter & receiver
    Can't explain why yours is ok, sorry.
    Silver03 is offline Member
    Apr 2006
    Colorado
    OK Jake. Sorry to bring this thread back from the grave again.
    I FINALLY got around to buying the boards and now have a solid LED. I cycled power on the freezer. After doing so, the blades were pointed toward the back of the freezer. They slowly turned themselves toward the front of the freezer however dont appear to be all the way down. No water is in the bin. I did make sure that the black tube isn't frozen.
    Any suggestions for a next step? Thanks again for the help.
  4. #24
    Thats odd, stick something up into that black rubber fill spout, I have seen ice clogs up in there where you can't see it.
    The blades are fine.
    a10acboy is offline Member
    Feb 2006
    Texas
    Default New icemaker
    Hopefully this won't be your issue, but about 3 weeks after I repalced the boards, my icemaker just stopped working. After some careful (and maybe not so careful) tinkering, I determined the motor had gone out. While I had it out I also noticed that the ice tray lining (teflon or something like that) had started to peel, so I decided to replace the whole thing. Again, hopefully this isn't your issue, and my icemaker going out at the same time the boards went out was just a coincedence.
    Good luck..
  6. #26
    Apr 2006
    Colorado
    Quote Originally Posted by Jake
    That was it man. Far inside the tube it was frozen. Dug it out and all is well now. Thanks again for the help, I really do appreciate it.
  7. #27
    Glad to help, and glad you found the extra ice blockage in that rubber fill spout.
    lurp316's Avatar
    lurp316 is offline Member
    Oct 2006
    st.louis
    Thumbs up
    This post is great. You helped me out alot.
  9. #29
    Thanks Lurp, glad it helped you out.
    lurp316's Avatar
    Oct 2006
    st.louis
    Question Help Jake
    Ok . now I need more help. ( mod 106.53632300)
    I replaced the emitter and receiver boards.(2 BLINKS FOLLOWED BY 1 SEC)
    Still no ice. No water. I pured water in the icemaker, it took 2 days to drop the ice.
    Is it the motor or the water vavle?
    I'm lost.
    and can I still buy the hole icemaker
  1. Whirlpool Cabrio UL & F51 Error Codes
    By VJH1968 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: April 13th, 2013, 11:31 AM
  2. Replies: 4
    Last Post: September 18th, 2012, 09:25 AM
  3. kenmore Ice maker not working--red light blinking
    By sard in forum Sears Kenmore
    Last Post: October 22nd, 2011, 12:29 PM
  4. kENMORE hE4T Codes / WHirlpool Duet Error Codes Link & f02
    By Tryspammingme in forum Sears Kenmore
    Last Post: April 30th, 2006, 10:00 AM
  5. Whirlpool Double Oven - E6 F2 Codes
    By Sarge in forum Whirlpool/Roper
    Last Post: April 16th, 2006, 01:20 AM
