Results 1 to 2 of 2
Thread: side by side not cooling (both sides) but no ice on coils - not sure its te compressor
    rpp
    rpp is offline Member
    May 2012
    vienna
    Default side by side not cooling (both sides) but no ice on coils - not sure its te compressor
    Model Number: MSD2641KES
    Brand: Maytag
    i posted this problem 2 weeks ago and had some good advice and some bad advice, but i still have a question.... here is the original post"
    "Both freezer and fridge stopped cooling suddenly. no ice on coils. fans are running, lights work. i've read about the adaptive control board and see there is a way to test it by jumpering two points forcing it to go from compressor mode to defrost mode. i am hoping there is a way to test it to go from defrost to compressor mode, since the compressor is not running. also, do the fridge and freezer have separate thermostats... if so, the thermostat(s) are not the culprits since both compartments stopped cooling at the same time. any other culprits if the board is not the problem??"
    here's why i think it may not be a compressor problem: even though the compressor is not running, i measure 120VAC at the input and, when the connector is removed, the start windings are at 4.2 Ohm, the run windings are at 3.3 Ohms, there is 8.3 ohms between run and start and there is no short between the pins and the compressor body.
    doesn't it make sense that the defrost control board could be forcing a continuous defrost? if that is the case, it would turn the compressor off but keep the fans running, right? is there a way to jumper the board to force the compressor on? if so, then i can determine if my compressor is good or not.
    does anyone out there know enough about the defrost control board to help me with this?
    RPP
    Ok RPP, all 3 of us techs here have told you the problem.
    Lock-up means your compressor internally won’t start the internal
    compressor piston, thus the compressor can’t start.
    Nothing will make the compressor run when its locked-up
  1. side by side not cooling (both sides) but no ice on coils
    By rpp in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 27th, 2012, 01:54 PM
  2. FIXED: GD5SHA Whirlpool side-side fridge : stopped cooling (both sides)
    By slaponte in forum Whirlpool/Roper/Estate
    Last Post: February 27th, 2012, 11:30 AM
  3. Whirlpool Side by Side No cooling Compressor not running
    By Jdenver in forum Whirlpool/Roper/Estate
    Last Post: September 15th, 2011, 09:59 AM
  4. GE Side by Side not cooling on both sides
    By RyanV in forum GE/Hotpoint
    Last Post: February 7th, 2011, 10:14 AM
  5. Replies: 7
    Last Post: June 28th, 2010, 11:14 AM
