Old November 25th, 2006, 03:02 PM
Gairloch is on a distinguished road
Default Drip from water dispenser after changing filter
Hi folks,
I hope someone here may be able to help me.
I have an LG fridge/freezer with an ice/water dispenser. All was working ok, until today,when I changed the filter.
All went well, filter is on, in correct flow direction, no leaks. I have ran through, what must be at least 30 pints of water, to clear the tubes, and hopefully to purge any air from system. Unfortunately I now have a small drip from the dispenser, not much but, maybe a couple of drips per hour.
Thinking that it was all ok until the filter change, I assume it must be something that Ive done, or not done during the installation. I searched the forum, and found the advice to run through at least 10 glasses of water to purge air from system, this I have done, as I said, at least 30 pints of water. I have made sure the supply pipe is fully turned on at the connecting valve, so the pressure should be ok (I've read that low pressure could cause the shut off valve in the dispenser not to close fully).
I now think that it may be the filter that isnt correct, and that maybe that is restricting the pressure, so that the shut off valve isnt closing. Is this possible?
The original filter for my fridge is a BL-9808, but when looking for a replacement, I got one here http://www.pozzani.co.uk/water-filte...duct_info.html
As you can see, it isnt a BL-9808, but supposedly a direct replacement, a GS10J.
So, my question is, does anyone think that this filter may be the cause of the problem, or have i possibly screwed something else up during the change?
Any advise, greatly appreciated
Regards
Gairloch
Old November 26th, 2006, 12:38 AM
I'm not sure if your LG is different than the ones here in the USA, so I always try to advise UK appliance help, if your located in the UK, here is a thread with some UK appliance help sites:
http://www.applianceblog.com/mainforums/showthread.php?t=2627
Old November 26th, 2006, 03:23 AM
Thanks for the info
Old November 26th, 2006, 11:35 AM
Glad to help Gairloch.
Water Dispenser SDX26VL jxp_app Amana 6 February 8th, 2007 11:49 AM
Whirlpool Gold water drip from dispenser wiznkids Whirlpool 11 November 30th, 2006 10:31 AM
Frigidaire SxS water dispenser is dripping water batman Frigidaire/Electrolux 2 June 13th, 2006 12:15 PM
Water Filter Bypass without a Bypass? yuzow Frigidaire/Electrolux 3 January 5th, 2006 11:47 AM
