Old May 30th, 2007, 03:27 AM
abrennh is on a distinguished road
Default GE fridge
I have a GE Model# TBX22RMR refrigerator and am getting water in the bottom below the crisper drawers. I cleaned the drain tube on back but it still gets inside any help would be appriceated. thanks
Old May 30th, 2007, 12:31 PM
Did you blow through your drain hose in the back and run hot water down it and see or hear it drain into your drain pan?
Old May 30th, 2007, 01:04 PM
Default water
I took the drain tube completly off and blew it out with an air hose and pulled the fitting off on the back where the tube attatches and applied suction with my shop vac on the fitting on the back. Harold
Old May 31st, 2007, 11:19 AM
Ok, then you may have to check inside your freezer behind your inside back freezer panel below your evaporator coils, there will be a drain hole thats probably clogged.
Kenmore Bottom-Freezer Fridge Icing up in Drainpan Hondatudinal Sears Kenmore 3 September 18th, 2007 08:46 PM
Kenmore s/s hot between fridge and freezer d213rr Sears Kenmore 9 July 28th, 2007 12:28 AM
GE fridge not to cold and making gurgling noises and shuts off when moved. oopsydaisy GE/Hotpoint 3 April 26th, 2007 11:27 AM
Jennair fridge side not cold after defrost wobbletop Maytag/Magic Chef/Admiral/Jenn-Air 7 September 20th, 2006 01:48 AM
msd2465ge - Fridge side not cooling MarkF2 Maytag/Magic Chef/Admiral/Jenn-Air 6 August 31st, 2006 12:43 PM
