Results 1 to 5 of 5
Thread: Ice maker fill tube frozen
    dayleh is offline Member
    Jul 2007
    Quaker City, Ohio
    Default Ice maker fill tube frozen
    I have a Kenmore Coldspot 106.70967990 and the ice maker fill tube keeps freezing up. I thawed it out about a month ago and it worked greast for about a month and now it has frozen up again. I tried to thaw it out again this time but it only dropped maybe 2 trays of ice and was froze up again. Any Ideas?
    Thanks for your help.
    ApplianceJunk's Avatar
    ApplianceJunk is offline Appliance Tech
    Aug 2005
    Milbank, South Dakota
    Low water pressure to the ice maker.
    Jul 2007
    Utah
    Low pressure is cause, but also it could be a valve that is not sealing when closing. Make sure the PSI to the refer is at least 30 PSI. DO NOT CONNECT THE REFER TO AN REVERSE OSMOSIS SYSTEM. You are only asking for trouble.
    Jul 2007
    Quaker City, Ohio
    what is the easiest way to check the water pressure and how would i increase it?
    Jul 2007
    Utah
    The easiest way to check your pressure is to go down to your local hardware store and get a pressure tester. Most have a hose fitting and you may have to get a adaptor for a 1/4 " pipe. Connect the hose at the back of the refer to the tester and see what your pressure is reading. If your pressure is normal (30-70 psi) you more than likely have a bad valve. If the pressure is low, call a plumber. Also check to water flow to the refer, make sure it is a good flow out the pipe.
  1. FIXED: Kenmore Coldspot Ice Maker Stopped Working
    Last Post: October 23rd, 2011, 11:34 AM
  2. Whirlpool ice maker water fill tube and cup freezing up
    Last Post: July 27th, 2007, 12:23 AM
  3. Unique Ice Maker Leak
    By gammonej in forum Sears Kenmore
    Last Post: April 9th, 2007, 12:43 AM
  4. Replies: 1
    Last Post: October 25th, 2005, 12:05 AM
  5. ice maker water tube leaking
    By justme in forum Sears Kenmore
    Last Post: September 11th, 2005, 01:44 PM
