Results 1 to 3 of 3
Thread: Kenmore Coldspot 106.57572791 not dispensing water
    .gif is offline Member
    Sep 2007
    Colorado
    Question Kenmore Coldspot 106.57572791 not dispensing water
    We just bought a house and the refrigerator that came with it is not dispensing water. The ice dispenser works fine. The water dispenser worked when we first looked at the house but not when we took possession. Given that the refrigerator just happened to stop working after we bought the house makes me wonder whether the previous owners removed something (like a water filter) when they left. I don't know if this model even has a water filter or where to find it or if the water dispenser requires it. The previous owners did not leave a manual. The water dispenser makes a slight buzzing noise when it is depressed. Could it be an electrical problem?
    Pegi at Sams is offline Appliance Tech
    Oct 2005
    Wichita Falls, Texas USA
    If there was something wrong with a filter you would not get water to the ice maker either....can you tell where the buzzing noise is coming from?? Could be from the water valve and it could have gone bad on the water side or the water line/water bladder behind the crispers on the food side could be frozen, see if the water bladder/line is frozen first then see if the buzzing could be the fill valve, follow the water line from the house to the frig to locate the valve behind the frig at the bottom, will have to pull the box out...
    Part#2188542
  1. Kenmore refrigerator water dispenser drips
  2. Kenmore ColdSpot IceMaker Leaking Water
    By SamIam in forum Sears Kenmore
    Last Post: June 18th, 2006, 11:48 PM
  3. Replies: 5
    Last Post: May 2nd, 2006, 10:48 PM
  4. Kenmore ColdSpot series 106 Water Depsenser Problem
    By GoogleMan in forum Sears Kenmore
    Last Post: April 2nd, 2006, 12:10 PM
  5. Kenmore ColdSpot 106.57572791 Water Dispenser Dripping
    By MtnMisty in forum Sears Kenmore
    Last Post: September 18th, 2005, 07:16 AM
