Results 1 to 4 of 4
Thread: Kenmore Cold Spot Leaking Water from Underneath
    KJDuggan is offline Member
    Sep 2007
    Los Angeles
    Cool Kenmore Cold Spot Leaking Water from Underneath
    Help! We have a Kenmore Cold Spot, Model #106-58282891, and it has been leaking water from underneath. Every morning there is a pool of water in front of the freezer door. We pulled the fridge out and checked the water line and the connection to the fridge hose, it is all dry.
    What could it be? Is there a hose under the fridge that may have broken? Is there a blockage of ice somewhere? Could it just be a clogged filter?
    Thanks for your help!
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    Hi KJ,
    Open the freezer door and look at the floor of the freezer. Is there any ice build up? My guess is you probably have a blocked drain line. When the refrigerator goes into defrost the water has no place to go except into the freezer. When it builds up enough it runs out the door. Does the water on the floor seem to show up every 8-10 hours?
    Rick
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Sep 2007
    Los Angeles
    Hi Rick,
    There was no ice or water on the floor of the freezer, and the freezer door seemed dry. It seems like the water was coming from under the freezer. And the puddling seems to be constant, that's why we thought it may be the water line.
    Thanks for your help,
    Keith
    Jul 2006
    Kieth,
    There is a connector for the water line just before it goes up through the door at the hinge. Check that first. You might have to pull the refrigerator away from the wall and remove the back cover. Use a flashlight and look at the drip pan for a leak. I haven't looked up this model and I'm assuming it has an ice-maker, correct?
    Rick
  1. Kenmore refrigerator water dispenser drips
  2. Kenmore 110.26842690, no cold water
    By bandit1trucking in forum Sears Kenmore
    Last Post: October 2nd, 2006, 12:25 PM
  3. Kenmore 80 Series No Cold Water During Rinse Cycle
    By poweruser in forum Sears Kenmore
    Last Post: September 1st, 2005, 07:24 PM
  4. Kenmore Elite not despencing cold water
    By marco97 in forum Sears Kenmore
    Last Post: August 29th, 2005, 10:40 PM
  5. Model 70 Kenmore cold water flows in at atrickle
    By Bruiser in forum Sears Kenmore
    Last Post: July 23rd, 2005, 05:19 PM
