Go Back   ApplianceBlog.com - Appliance Repair Forums > Appliance Repair Talk > Microwaves > Sears Kenmore
Old November 9th, 2007, 09:51 AM
RCaH is on a distinguished road
Default Kenmore Microwave 721.80012401
It's an over-the-range appliance with touch pad. Everything works, light, clocks, turntable turns, timer works, EXCEPT suddenly it does not heat and operating noise is super loud. Bought from Sears in June 2006. Do I pay upwards of 100 bucks to have someone come look at it, or do I junk it?
Old November 10th, 2007, 09:16 AM
Sounds like you need a new diode. Part# 6021W1A001D
Old February 24th, 2008, 03:07 PM
rss0213 is on a distinguished road
Default me, too?
I had a similar issue. Bought in December, 2006, dies in early Feb. of this year....less than 2 months after manufacturer's warranty expired. I took mine to a repair shop for a free estimate, and they told me it was the magnetron. They said it would cost $130 to fix it. I can get a replacement for a little more than that. Is this something I can replace myself?
Old February 24th, 2008, 03:24 PM
Default RepairClinic.com does not have model number in database
When I search for this model number on the repairclinic.com web site, it does not find this product....makes it hard to figure out which part is needed if they don't know your model number.
Old February 24th, 2008, 04:05 PM
What is the model number of your microwave? The magnetron is easy to replace. Either 2 or 4 3/8" nuts hold it on. You need to short the terminals on the capacitor to discharge it first. You may run into trouble getting the cover off. Most have security screws holding it on like torex screws with a pin in the center. There may also be a thermostat on the tube that you will need to transfer to the new one. This repair is about a 2 on a scale of 1-10.(10 being the hardest)
Old February 25th, 2008, 03:38 PM
Thanks for your help...
The model number is 721.80012401 - same as previous post in this thread.
How do I go about "shorting" the terminals on the capacitor?
Is there a special tool needed to remove the security screws? I guess I should update you later about what they look like.
Old February 25th, 2008, 04:11 PM
http://www.applianceaid.com/micro.html
Yes. Many different ones.
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old February 26th, 2008, 03:05 PM
Does anyone know the tool that is needed for this model?
Old February 26th, 2008, 03:37 PM
There are all kinds of security screws. Looking up the model number most likely won't say which ones. It's probably a torx screw with a pin in the center. If so you'll need a torx bit with a hole in the center. You probably won't find them at your local Sears or home centers. Look for a tool store that carries a large selection of tools. Last resort use a dremmel with a cutting wheel or drill it out.
kenmore microwave 721.62629200 fan stops running during cooking cooke Sears Kenmore 3 August 28th, 2006 04:09 AM
Kenmore Microwave F6 code ldcnelson Sears Kenmore 1 March 5th, 2006 04:51 PM
Kenmore Microwave 721.63652 Humidity Sensor jimh Sears Kenmore 5 February 27th, 2006 04:52 PM
Kenmore Microwave freaking out... jwatkins Sears Kenmore 1 February 6th, 2006 04:28 AM
Kenmore Elite Microwave F9 Error bill252 Sears Kenmore 1 October 27th, 2005 09:55 PM
