Old August 27th, 2005, 05:45 AM
thegreatoz is on a distinguished road
Default Kenmore 80 series won't fill...
I'm having some trouble with my washer, model 110.27812692. It won't fill normally during the wash. It seems the only way to fill is to cycle the level control switch between small/large load, then the tub will fill. Once it does fill, the water level looks low to be on the high setting. When filling, the water flow looks normal, so I don't suspect water pressure issues.
Any ideas? Would this be a good DIY project for a newbie?
THANKS
Old August 27th, 2005, 06:42 AM
Sounds like you have a bad pressure switch, but i would first check to see if something is obstructing the air dome by blowing into that clear rubber hose that connects to the pressure switch with the tub empty.
Its not to hard to check this, just open the console:
Removing the End Caps on Kenmore model#110 Whirlpool built
Then Pull forward and up on the console and you can hinge it open, hanging from the hinges.
More info here:
Part#3366846
Water fill level pressure switch
Kenmore 70 Series - tub won't fill mbckmyr Washers 1 April 1st, 2007 10:12 AM
Kenmore Series 80 Fill Issue rjaltonjr Sears Kenmore 3 March 7th, 2007 07:59 AM
Kenmore 70 series 11022722100 doesn't fill mike56p Sears Kenmore 3 January 1st, 2007 07:32 PM
Kenmore 70 Series wont fill Gaidin Sears Kenmore 5 December 6th, 2006 10:00 AM
Kenmore 665.15862990 no water during fill cycle utspam Sears Kenmore 1 July 19th, 2005 09:04 PM
