Recently My old Kenmore Dryer Went out The Timer went out first than less than a week later there was no more heat. I think that the heat went out due to the timer not working and the heater working for way too long. Can someone help? It is an old dryer, but I have no money to replace. Are there online instructions? Where can I buy parts?
Thanks |
Can anyone help
Could you post the model number? When you say the timer went out what do you mean? Did you have to replace the timer for the dryer to work again? Did the timer just stop advancing? If the dryer would still start but the timer no longer advanced would it not advance on any cycle or would it not advance on the auto cycles only? Please post a model number and I can look up what you have for a dryer and get a better idea what you are looking at. |
Where do I find the model #?
The timer stopped advancing on the automatic/wrinkle guard side, but will advance on the touch-up side No I did not have to replace the timer, I am cheap so I need to fix that the cheapest way possible, I have just been using the touch-up timer |
The model# is on inside front panel as you open the dryer door.
Yours may have a resistor that is attached to the timer, check that with a meter for the proper reading. Also check the sensor, if yours has one and the cycling thermostat. More info is here: http://www.applianceaid.com/whirlpool-dryers.html Jake
| Kenmore 110.70712990 Gas Dryer Timer Doesn't Stop & Won't Heat | Irelnd4evr | Sears Kenmore | 5 | June 16th, 2007 03:49 PM |
| Kenmore Elite Ser. 70 Dryer 110.67612690... Timer Stops and no heat | BaerEssentials | Sears Kenmore | 1 | December 26th, 2006 09:40 PM |
| kenmore heavy duty 70, series 110 won't spin, drain or agitate | anguyen | Sears Kenmore | 4 | August 24th, 2006 01:57 PM |
| Kenmore 70 Series timer not moving & no heat | yosemity71 | Sears Kenmore | 3 | August 21st, 2006 02:24 PM |
| Kenmore 80 Series heavy duty washer fills with water and then does nothing. | Cubby007 | Sears Kenmore | 3 | June 8th, 2006 07:25 PM |
