Go Back   ApplianceBlog.com - Appliance Repair Forums > Appliance Repair Talk > Microwaves > Sears Kenmore
Old December 8th, 2007, 12:10 PM
Flarkblam is on a distinguished road
Default Kenmore 721.62642200 intermittent oven light
Everything about this microwave works flawlessly except that the interior oven light will decide to not be on "sometimes." It's been like this for over a year and I've just been waiting for something else to go wrong to lead me to the problem. Right now it's only a minor nuisance. Since it's been a while I figured I'd ask on here to see what I should look at first. In summary - when you open the door sometimes the light will come on and some times it won't. Every blue moon it will flicker a little bit but I can't seem to get the problem to replicate on demand. What should I yank apart first?
Old December 8th, 2007, 12:43 PM
ApplianceJunk's Avatar
Make sure the bulb is tight in the socket.
Old December 8th, 2007, 03:39 PM
Default Checked
I went in there and double-checked on the tightness. It's tight. So then I opened and closed the door over and over until it stayed off. Then, while it was off with the door opened, I tapped on the top inside of the oven and it popped back on. Should I replace the socket? Should I not even mess with it?
Old December 8th, 2007, 08:04 PM
It just sounds like a bad filament in the bulb, have you tried to replace it with another new bulb?
Old December 9th, 2007, 09:54 AM
Could be:
- loose bulb
- bad bulb
- bad socket
- bad relay on the board
- loose wire
Go simple first....check for a tight bulb, check socket and replace bulb.
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
kenmore gas range oven won't light yvonneb Sears Kenmore 9 November 23rd, 2007 05:53 AM
Kenmore gas range - oven burners won't light squirkie Sears Kenmore 3 November 7th, 2007 08:06 PM
Year Old Kenmore Gas Oven Won't Light maggie2853 Sears Kenmore 3 March 15th, 2007 01:27 PM
Kenmore gas oven 362.72295790 oven won't light bandit1trucking Sears Kenmore 1 November 19th, 2006 11:36 PM
Kenmore 790 Gas how to fix oven light plunger panda7 Sears Kenmore 8 June 15th, 2006 11:28 PM
