January 3rd, 2008, 01:52 PM
Clean between glass on oven door
We have a three year old Kenmore Model 790 electric range. Some liquid must have dripped down inside the door. Now the glass has a streak that we can not remove from the glass on the inside or outside, so the streak must be between the two layers of glass that are the window in the oven door. How can I get to it to clean it and what should I use?
January 3rd, 2008, 08:53 PM
We would need your complete model#, its located on the bottom of your range when you pull your storage drawer out, it should be on the left or right side leg frame.
January 3rd, 2008, 09:36 PM
Our complete model number is 790.96324401.
January 4th, 2008, 12:10 AM
Here's the parts diagram for your oven door:
http://c.searspartsdirect.com/lis_pn...0038-00004.png
Just remove the 4 screws#60B and then that glass frame should come off, you may want to have someone help you hold the glass while you take the frame off.
January 5th, 2008, 11:46 AM
Cleaning Glass in Oven Door
Thank you. We did it this morning. First we removed the door from the hinges and laid it on the kitchen table. Thanks to your help, taking the outside glass off so we could clean the inside surfaces of both panes of glass was much easier than I expected.
January 6th, 2008, 02:40 AM
Good job, glad you got it cleaned.
August 9th, 2010, 08:57 PM
We just bought our Kenmore stove and imagine that...we haven't even had it a month and we already have a drip between the 2 Panes of glass...help!! Our Model number is: 790.688432
August 10th, 2010, 09:51 AM
Please double check your model#, that one doesn't show as good.
The model# tag is located at the very bottom front on the left or right side after you pull out the storage drawer.
August 10th, 2010, 11:19 AM
lol I reversed the first 2 numbers, it's C970-688432.
August 10th, 2010, 05:35 PM
Canadian model? Oh boy, can't look that one up, we don't have access to Canadian models here.
Jeff may be able to help you, he lives and has a appliance shop in Canada.
You can go to Jeff's q&a section here:
Question and answer forum entrance for Appliance repair helps
By hammesd in forum Sears Kenmore
Last Post: October 10th, 2012, 02:29 PM
By ricke in forum Whirlpool/Roper
Last Post: July 17th, 2011, 11:55 PM
By Jimbo3322 in forum Sears Kenmore
Last Post: October 3rd, 2007, 12:46 AM
By mandapanda in forum Sears Kenmore
Last Post: September 25th, 2006, 06:06 PM
By leeberg in forum GE/Hotpoint
Last Post: September 29th, 2005, 07:49 AM
