Look-Up & Order Appliance Parts Classifieds Shop Home Appliances Appliance Blog Home Appliance News
Closed Thread
Bookmark and Share LinkBack (2) Thread Tools Search this Thread Display Modes
  2 links from elsewhere to this Post. Click to view. #1
Old January 29th, 2005, 08:38 PM
jgaines is on a distinguished road
Post [FIXED] Kenmore Dishwasher goes to next cycle before water full
Kenmore Model number 66516912001
This will take a bit of explanation:
1. The dishwasher was not getting the dishes clean.
2. I measured heater resistance - heater was dead.
3. I replaced the heater. Case closed, I thought- but dishes were still not clean.
4. With voltmeter, I can see that heater is getting voltage and working. Trouble found: The water does not fill enough during the fill cycle to trigger the "full" sensor (the float). The heater is not in good contact with the water because water is not high enough. I suppose this is why the first heater died - it got too hot and burned out, because it was in poor contact with the water.
5. I disconnected the supply line at the fill valve and ran it into the sink. There is good pressure there. I checked for blockages in the line from the fill valve to the dishwasher tub. No problem.
6. I energized the solenoid, and water flows out at what seems like a reasonable speed, but I guess it isn't enough to fill in time. On the timing sheet it looks like the machine goes on to the next cycle after 1 min, 35 seconds, whether or not the float switch has switched. If I blow into the fill valve when energized, I can get some air through, but it isn't a lot. If the fill valve is not energized, then I cannot blow anything through at all - as expected.
Question: How much resistance should I expect from the fill valve when blowing through it? What else can I do to correct/define the problem? Do I need to replace the fill valve? Is there any way to lengthen the water fill time? I think that another minute would be enough - it's not like it is very far from being full enough.
Old January 29th, 2005, 11:00 PM
Post imported post
Hi, I have had many of these dishwashers do exactly what your saying, Not cleaning the dishes, Your water pressure seems fine, and none of these dishwashers are designed to fill up over the heater, thats not the problem, The problem i find on these is the Check Valve and the Chopper in the Pump is bad, If you check my blog, you will see many entries where i have fixed this same design dishwasher.
http://www.applianceblog.com/archive...er_chop_1.html
Check Valve Part#8268375
Chopper Part#8268383
http://www.applianceblog.com/archive...02_kitche.html
Model#KUDR01TJBL0 : Not cleaning/washing well, Found check valve bad, part#8268375, replaced, worked great.
http://www.applianceblog.com/archive...n_aid_dis.html
Model#KUDS01DJBL1 : Not cleaning the dishes well, Found Check valve bad, replaced, worked great.
http://www.applianceblog.com/archive...ay_sept16.html
2004 Kenmore Dishwasher(Whirlpool built): Smell oder, not cleaning dishes well, Found check valve in pump bad, replaced, worked great.
http://www.applianceblog.com/archive...aturday_1.html
Customer was complaining of dishes not getting as clean. Installed new check valve and chopper blade assembly in sump(pump). Chopper was broken. The check valve is the small rubber flapper in sump(pump) that can stick and not allow proper water flow to spray arms. Replaced both, worked great.
The Kitchen Aid and Whirlpool uses that exact same Check Valve and Chopper.
Here is a bulletin on this issue as well, all the Kenmore 665. models are made by Whirlpool:
http://adcxns1.whirlpool.com/Service...LE/8178191.PDF
Its says you need to order a new middle spray arm Part#8269024
Hope that helps.
Old January 30th, 2005, 10:51 AM
Dan O.'s Avatar
Post imported post
jgaines wrote:
The float and float switch are just safety devices to prevent overfilling and flooding. Under normal operation they should NEVER be activated.
As Jake already said, it isn't suppose to be.
JFYI
Dan O.
Appliance411.com
=D~~~~~~
Old January 31st, 2005, 06:49 PM
Post imported post
Thank you very much! I looked at the chopper in the past and did not see any problems there, except that a button was trapped on the screen. I removed the button long ago. I will have a look at the check valve. I have let the dishwasher start up and then opened the door and seen that water was spraying out of the arms, but maybe the pressure is too low because of the check valve not working right(?).
Old January 31st, 2005, 07:53 PM
Post imported post
Hi Jgaines,
Its most likey the check valve , that controls the water flow pressure.
Heres a series of pictures:
The check valve is just to the right of this chopper(just out of the right side picture) Pull the Black rubber check valve up with a screwdriver, then install a new one, i bet you will see it works well after that.
clinet (November 11th, 2008)
Old February 1st, 2005, 03:53 AM
Post imported post
Nice pics!
I also learned something!
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old February 1st, 2005, 07:39 AM
Post imported post
Thanks Jeff.
Old February 1st, 2005, 07:41 AM
Post imported post
Thanks Jeff.
Old March 12th, 2005, 10:53 AM
rc-b is on a distinguished road
Post imported post
Hi, I have Kenmore Elite 665.16462300.
I am am trying to find a repalcement flapper valve that lives in the feed tube assembly shown in your second photo. The check valve is supposed to be opened by teh upper spray arm probe.
In my case, one check valve is always flapped open and so hardly any water goes up and out the upper spray arm. So far, onl y the $45 complete feed tube assembly is offered by Sears or other common parts sources.
My glasses were sparkling clean for 10 months or so, and now"we" have to clean them by hand (just passed a year on installation). I say "we" meaning my wife actually finally complained to me and I took apart the feed tube, checked the grinders and screens and then found your Blog.
Many Thanks for help sourcing the part. Rob
Old March 12th, 2005, 05:29 PM
Dan O.'s Avatar
Post imported post
rc-b wrote:
I am am trying to find a replacement flapper valve
Click on the picture of the flapper valve (shown on a grid background) above. It will take you to a site where it can be purchased.
JFYI
Dan O.
Appliance411.com
=D~~~~~~
Closed Thread
LinkBack to this Thread: http://www.applianceblog.com/mainforums/sears-kenmore/124-fixed-kenmore-dishwasher-goes-next-cycle-before-water-full.html
Posted By For Type Date
Dishwasher doesn't wash well. - FixYa This thread Refback September 25th, 2009 06:31 AM
Whirlpool Dishwasher - HomeTips Forums This thread Refback September 6th, 2009 05:48 PM
Kenmore 665.16791791 water heating slow? haus Sears Kenmore 3 January 16th, 2007 09:01 PM
Kenmore dishwasher model 665.15831793 not sensing correctly jton Sears Kenmore 14 March 28th, 2006 09:58 PM
Kenmore 80 Series No Cold Water During Rinse Cycle poweruser Sears Kenmore 3 September 1st, 2005 06:24 PM
Kenmore 665 Dishwasher Cycle Completion apotter Sears Kenmore 1 May 3rd, 2005 08:49 AM
Powered by vBulletin® Version 3.8.5
© Applianceblog.com 2004 - 2010
