Old January 23rd, 2008, 04:27 PM
Brady is on a distinguished road
Default Kenmore 110 Washer not spinning or pumping
Hello,
My 3.5 yr old Kenmore Washer Model 110 24722300 is not spinning or pumping out water after the water has completly filled the tank. When the timer gets done with the fill cycle and gets to the spin cycle the washer stops. The timer does not continue to run through the remaining cycles.
Any thoughts or help?
thanks in advance
Brady
Old January 23rd, 2008, 11:13 PM
Hi Brady,
Does it still agitate fine after it fills with water?
When you close the lid do you hear a click sound just before its down?
If not, then its likely you have a bad lid switch.
Manufacturer's Number: 3949238
Old January 24th, 2008, 02:35 PM
It does not agitate at all. One the water fill is done everything stops.
Brady
Old January 24th, 2008, 06:35 PM
Ok,
Old January 25th, 2008, 04:14 PM
I replaced the lid switch and now everything works
Thanks a lot for the help
Brady
Old January 25th, 2008, 09:57 PM
Sounds good Brady, glad that was it.
Kenmore 90 series washer not spinning candicec Sears Kenmore 9 June 26th, 2009 08:21 AM
Kenmore Portable Washer 110 48184790 lonestardeals Sears Kenmore 4 November 5th, 2007 09:08 AM
Kenmore 90 series washer #110.22912100 not spinning cajundohboy Sears Kenmore 3 September 22nd, 2007 07:01 PM
Kenmore washer not spinning twintle Sears Kenmore 2 April 25th, 2007 08:51 PM
Kenmore washer not spinning mislam Sears Kenmore 3 March 19th, 2006 09:32 AM
