Results 1 to 10 of 12
Thread: Kenmore 90 series dryer won't start
    lbtnh is offline Member
    Sep 2005
    Default Kenmore 90 series dryer won't start
    Model 110.66902690 Kenmore 90 series dryer won't start. Push button, nothing happens. Checked circuit breaker, power is OK. A couple of weeks ago, when it still worked, I noticed that the timer didn't always move to 'OFF'. It would keep running until I manually turned it off. Clothes dried fine.
    Thought I'd change out the thermal fuse (and check the venting) I'd read about in other threads.
    Anyone have any other ideas? Thanks.
    Mad Mac is offline Appliance Tech
    Jan 2005
    Moorpark (via Motherwell, Scotland), California, USA
    Nothing happens? Any sounds at all? Drum lamp working?
    Sep 2005
    Drum light blew out ages ago. If I hold in the start button, I hear a click, then a faint tick tick tick tick tick tick ...
    Sep 2005
    For the record, it was the thermal fuse and blocked (lint-filled) venting.
    LindySD is offline Member
    Sep 2005
    New York
    Unhappy Same Problem
    Please help. This morning I tried to start my dryer and experienced the same. problem. It just won't start. It doesn't make any sound at all. I'm new to this board and forums in general. If anyone can shed some light, especially in regard to a thermal fuse, I might have a place to start. Aside from this problem, the dryer has been working fine. Appreciate the help.
    Quote Originally Posted by LindySD
    Is yours the same model# as the person above? If not came you please post yours here.
    First check your breaker box for a tripped breaker, If its ok, then you will need a volt/ohm meter if you plan on doing the checks and tests yourself, cause you will need to ohm the thermal fuse to check for continuity, then check the voltage to the dryer, if electric should be 240 volts, if gas 120 volts.
    Jeff1 has a great web page on dryer testing:
    http://www.applianceaid.com/dryers.html
    Sep 2005
    New York
    Thanks for the response. My model is Kenmore 77902791. After some testing we find the dryer will work for 10 minutes or so and then stop. Had a repairman come over who, after hardly any time at all, said the motor was dead. Any ideas?
    After it stops in 10 minutes, when you try to restart it what happens? Any humming sound, any sound at all?
    Sep 2005
    New York
    No, no sound after it initially stops. But after it rests for a while it will start again.
    Sounds like the motor is overheating causing it to shut off on its overload switch. Motors can be high in cost.
  1. Kenmore 70 Series Dryer Won't Start
    By KCFaninSTL in forum Sears Kenmore
    Last Post: January 17th, 2012, 02:00 PM
  2. Kenmore 70 Series Electric Dryer will Not Start
    By planz in forum Sears Kenmore
    Last Post: December 4th, 2005, 05:18 PM
  3. Kenmore 70 Series Dryer Won't Start
    By julian_001 in forum Sears Kenmore
    Last Post: October 19th, 2005, 07:51 AM
  4. Kenmore 90 series dryer won't start
    By supermancs in forum Sears Kenmore
    Last Post: June 6th, 2005, 11:27 PM
  5. Kenmore 90 Series Gas Dryer Problem
