My Kenmore 665.15953000 dishwasher runs only on Normal Cycle. Other cycles no longer can be selected. Also the cycle is too long. Resetting the power and running the diagnostics did not fix anything. I suspect from reading other posts that either the Electronic Control (Part# 8269187) or the Console Assembly (8269754 - Graphite) need replacing. Is this correct? How do I know which one to replace?
Here are the details:
Thanks! |
First check your ribbon cable that connects the keypad assembly to the control board, we've had a few members say they have seen that get burned/bad spots in it and cause the dead buttons. Here's the one for your model: Manufacturer part#8269739 is RepairClinic item#906151 ![]() Here's the complete control panel which includes the ribbon cable: Manufacturers Part# 8269754 Its much higher than your ribbon cable alone, so if the ribbon cable looks fine then you'll likely need this control panel assembly. For the long cycles, your control board controls that, here's the one for your model: Manufacturers Part# 8269187 Its not unusual to have both parts fail, I've seen this happen on a few I worked on as well. Jake
