I have a Kenmore series 70 model # 110.20712990 that just makes a grinding noise when it reaches the spin cycle. It does drain the water, but sounds like my old VW bug after I played mechanic on it...... ANy help would be appreciated.
WHen I moved the washer, I found a peice of white plastic beneath it. Being the "detective" I am, I turned the machine on its side and found a broken white "thing" I have no clue what I am looking at so I attached a photo. Hopefully someone can make an identification from what I have.
OK not fair...answering my own questions. The motor coupling was trashed, broken into peices. I will hopefully pick up a new set tomorrow. Is there anybody that thinks that this is the problem? or did I stumble across an unrelated issue?
THanks |
Your better than you thought, answering your own questions. ![]() Yup, from that photo looks like your motor coupling is broke. Here's the motor coupling for your model: Manufacturer's Number: 285753A Read #2 and #5 here on how to access and change it: http://www.applianceaid.com/procedures.html Before you put the new one on, turn that gearcase shaft clockwise and counterclockwise to make sure its not locked it and turns fairly easy. I've seen gearcases lock-up and snap that puppy clean off. Jake
THanks!! I will check the gearcase shaft as soon as I get home from work.
Sounds good, let us know the outcome.
Good to go!! two successful loads of laundry with no trouble. THe spin cycle seems to stop more abruptly than I remember, but the wife is happy
Good job fixing it, glad its running again.
| maytag washer doesnt spin or agitate | sun45 | Maytag/Magic Chef/Admiral/Jenn-Air | 1 | March 17th, 2007 12:40 PM |
| kenmore 80 series washer no spin or agitate | brooklynjim | Sears Kenmore | 1 | August 22nd, 2006 11:56 AM |
| GE Washer Fills but won't agitate, spin or drain. | jaytango | GE/Hotpoint | 5 | May 14th, 2006 12:50 AM |
| Whirlpool washer won't agitate...but will spin | steph23 | Whirlpool/KitchenAid | 1 | May 8th, 2006 06:38 PM |
| Frigidaire front load washer won't agitate or spin | bigwilliecrash | Frigidaire/Electrolux | 1 | March 14th, 2006 05:54 PM |
