My icemaker is dripping on my Kenmore Coldspot 106.70262990 refrigerator.
Here's a pic: ![]() What should I inspect/replace? Thanks! -n. |
You'll need a new ice maker module. Here's the ice maker module for your module you can order: Manufacturer part#W10122536 is RepairClinic item#1373103 W10122536To change it, take your ice maker out by taking the 2 screws out from the top, and the 1 on the bottom, that mounts it to your freezer wall, unsnap the electrical connector. Then remove the front cover, just unsnaps. Then remove the 3 screws that hold the module in place as seen here: http://www.applianceaid.com/icemaker-modual.html then remove the metal bar that snaps into that plastic sensor piece on the module. Jake
Jake, What causes this? I have a similar problem on my Treo. It drips some every time it ejects ice and I get a small clump daily. Thanks, Bob
On the module style ice makers (Whirlpool, Maytag Family, Sub Zero) the printed circuit in the module head often wears and the contacts become too long and allow the icemaker to over fill = new ice maker or new module head. This is from Jeff's site, www.applianceaid.com Jake
Jake, One more question. The model is Kenmore 596.73502202. I did a parts search at repairclinic.com and it likes like I have to replace the entire ice maker. Is that correct? There's no sub-assembly? Thanks, Bob
Yes, thats true on your model Bob.
![]() You can save some money, I found it on sale for $89 here: Manufacturer's Number: D7824706Q Jake
Thanks again Jake! So this fits a kenmore Treo? Just making sure as the maker is listed as Amana and or Maytag. repairclinic.com had suggested replacing the water inlet valves, which cost almost as much as the entire ice maker. Bob
Yes, this is the one for your model, your Kenmore 596 model is made by Amana.
You water inlet valves should be fine. ![]() If case you ever need them, you can order them here: Primary water inlet valve: Manufacturer's Number: 12544002 Water valve kit: Manufacturer's Number: 12002193 Jake
It looks like the new one is working OK. That was the easiest icemaker repair I've ever done. Whoever designed that one and the freezer did something correct. Thanks, Bob |
Excellent Bob, good job fixing it.
| 18" under cabinet icemaker | dago52 | KitchenAid | 0 | November 11th, 2007 10:20 PM |
| Another Whirlpool Gold Icemaker gone bad... | Traveler999 | Whirlpool | 9 | June 28th, 2007 04:40 PM |
| Icemaker Problem on GE Profile Refrigerator | caf@e-navtech.com | GE/Hotpoint | 1 | June 27th, 2007 09:13 PM |
| Kenmore 106.56532400 Icemaker and Voltage | crawdad77 | Sears Kenmore | 2 | May 25th, 2007 09:24 PM |
| Kitchenaid Icemaker won't harvest | icecat14 | KitchenAid | 1 | February 7th, 2006 10:35 PM |
