The fridge side of our Kenmore never seems to get below 40 degrees. The freezer side holds steady around 0-5 degrees. At least once a month, the fridge approaches 50 degrees and I have to take the back panel out of the freezer to melt all the ice off of the evaporator with a hair dryer. It gets totally clogged with ice so that no air could possibly move thru it. Any ideas as to why this happens once a month?
Thanks, Denny |
Hi Denny,
There should be a diagnostics sheet behind your front bottom kickplate grill, it just snaps off, pull hard. If your heater element and defrost thermostat test good, then it has to be a bad control board. You would need a volt/ohm meter to check for continuity on the heater element and defrost thermostat(while frosty). #33 here: http://www.searspartsdirect.com/part...4027-00011.png is your heater element and #35 is your defrost thermostat. Both are located inside your freezer section behind your inside freezer lower back panel. #6 here: http://www.searspartsdirect.com/part...4023-00010.png is your main control board that controls your auto-defroster Sears wants $208 for it, You can get it here for $150: Manufacturer Part# 8201660 Jake
| Kenmore Coldspot freezer perfect, fridge warm | nandof | Sears Kenmore | 2 | July 1st, 2007 10:49 AM |
| Kenmore 106.56569400 fridge side warm - evaporator keeps frosting up | Denman | Sears Kenmore | 7 | June 23rd, 2007 09:47 AM |
| Kenmore side-by-side...fridge side warm but freezer side fine | jpp816 | Sears Kenmore | 18 | May 18th, 2007 11:17 AM |
| Kenmore Elite SxS warm on Fridge side | BWinMinnesota | Sears Kenmore | 3 | September 17th, 2006 11:56 PM |
| Kenmore Cold Freezer - Warm fridge Frost free failure | rkgrp | Sears Kenmore | 4 | April 4th, 2006 01:52 PM |
