opps i forgot to say it is a calypso. hello i talked a while back about a Leaky ring around the top of the washer which was a small leak now i had a code fl come up and i drained the washer and got it to agitate and run tell when it is supposed to drain one time i didn't get enough water out i guess then i got a ld i know what the fl and ld codes are my question is . do you access the pump from the bottom of the washer i got the ft off but don't look like you can get it off ? and the last time i could smell the pump motor get hot to hot to touch so i turned it off so i hope fully didnt burn out the pump . would some thing get in the pump to seize it ? how much for a new pump? or impeller if that is the only prob thanks kelly
Hi Kelly, Welcome Back.
Just to keep everyone up to speed, here's the model# of your Kenmore Calypso washer from your previous posts: Model# 110.22062100 Yes, I've seen lots of these older style pancake water pumps get clogged easy, they have now upgraded the water pumps to these: Here's the upgraded pump you can order: Part#285990 Here's a help link: http://www.applianceaid.com/calypso.html Here's the repair manual that shows you how to access the water pump: https://secured.whirlpool.com/Servic...LE/8178010.pdf Jake
thanks jake i tried to clean the hair and strings out of the impeller it worked for 5 loads then it did the same thing . so i am going to get a new pump for it. the manual for the whirlpool is a newer model . did whirlpool buy out Kenmore ? is that why the different names? i still haven't looked at the fridge yet . maybe some day lol thanks again kelly
The Kenmore models starting starting with model#110 are always made by Whirlpool.
Ok, whenever your ready to check your refrigerator were always here to help Kelly. ![]() Jake
thanks jake i bought a new pump and now it works fine thanks on the info on the repair i wonder why it says Kenmore not whirlpool . thanks again kelly
Glad its working good again Kelly.
![]() Your Kenmore is made by Whirlpool, what says Kenmore? Jake
on the top of the washer it sayes kenmore elite kelly
Yup, Kenmore has a contract with Whirlpool to make their washers, So thats why it says Kenmore, but its built by Whirlpool.
that is good to know thanks . kelly
Glad to help Kelly.
| Kenmore Elite Washer not draining | kogawa | Sears Kenmore | 5 | October 9th, 2007 01:04 AM |
| Kenmore Elite, are installation and mounting the same?? | Bulldogntn | Sears Kenmore | 0 | July 17th, 2007 08:16 AM |
| Kenmore Elite model no. 665.15987990 won't drain | zippy | Sears Kenmore | 7 | March 7th, 2007 10:55 AM |
| Kenmore Elite Side by Side seemed to stop working | Boilerace | Sears Kenmore Brand Forum | 0 | August 10th, 2006 10:29 AM |
| kenmore 80 - draining while agitating | nasus | Sears Kenmore | 1 | March 4th, 2006 10:57 AM |
