Old May 4th, 2008, 12:22 PM
2olkdzak is on a distinguished road
Default Kenmore Gas (Propane) Oven
I have a Kenmore gas range, model #362-7596091. The oven decided to stop working and my diagnosis was that the ignitor was faulty.
I purchased a new ignitor, but for the life of me can't seem to get a good grip with a 1/4" box end wrench on the hex-head screws that are underneath the ignitor bracket!! I'm concerned that I will round off the heads and really be up a creek!!!
Can the burner tube be safely removed (and re-nstalled) so that I can get at the screws? I took it loose at the front of the oven and lifted it a bit to try and get a better grip on the screws without success, and I was reluctant to tug on it as I don't know how it is attached.
Brett
Old May 4th, 2008, 10:01 PM
Hi Brett,
Yes, the burner tube can be safely removed and re-installed. Once you have it free in the front, you just lift it up and out, looks like on this one you have 2 screws in the back of the burner tube that need to be removed first.
Here's the oven burner tube for your model:
Manufacturer's Number: WB16K22
icon
icon
iconWB16K22
Old May 5th, 2008, 06:27 AM
Hi Brett,
Those two screws have tormented service techs for 20 years even before electric igniters when they held the pilot assembly. If you're having a hard time with them then you're doing the right thing by taking out the manifold. You might still have to cut them off. Good luck.
Old May 5th, 2008, 08:01 PM
Thanks guys! I REALLY appreciate your assistance and advice. I wasn't aware of the two screws holding the burner tube, so that was tremendous to learn!!!
I will soldier on and git 'er done. (I hope)!
Again, thanks
Brett
Old May 5th, 2008, 10:36 PM
Sounds good Brett, let us know the outcome.
Old May 6th, 2008, 08:37 PM
Hi Jake,
Great news!
I managed to squeeze into the oven (like a Thanksgiving turkey LOL) and remove the two screws holding the burner tube in place. And, miracle of miracles, I didn't drop either one! Amazing! Then, it came right up and out. I then removed the screws attaching the ignitor to the burner tube - I would have never been able to get them out w/o taking out the burner tube.
Now I need to put the new ignitor on, snip the wires, wire nut them (the appliance parts guy gave me two ceramic (?) wire nuts, stick that burner tube back in, and fire that bad boy up (not literally of course!) and bake some cornbread LOL
Thanks again, you all are great, couldn't have done this without your support.
Brett
Old May 7th, 2008, 12:19 AM
Good job Brett.
kenmore gas range oven won't light yvonneb Sears Kenmore 9 November 23rd, 2007 05:53 AM
Kenmore gas range - oven burners won't light squirkie Sears Kenmore 3 November 7th, 2007 08:06 PM
Kenmore gas oven slow to heat up t7044wa Sears Kenmore 5 November 6th, 2007 03:43 PM
Year Old Kenmore Gas Oven Won't Light maggie2853 Sears Kenmore 3 March 15th, 2007 01:27 PM
Kenmore gas oven 362.72295790 oven won't light bandit1trucking Sears Kenmore 1 November 19th, 2006 11:36 PM
