Old June 7th, 2008, 04:52 PM
findmatt77 is on a distinguished road
Default Terminal block replacement issues
When looking under the hood of a Kenmore range(911.93712020) I discovered the terminal block below. Scary stuff!
So I bought a replacement terminal block at Home Depot(see packaging below). But now after installing the new terminal block, the burner element doesn't heat. I'm stumped and while I'm pretty handy, I don't know much about ranges.
Something that seemed strange: the wires that lead to the new terminal block have voltage running through even though the switch is set to off (I measured this with one of those voltage pens meant for wall outlet). The other 3 burners show no voltage when they're set to "off".
I'd welcome any advice or input. Thanks.
Terminal block replacement issues-p1000835.jpg   Terminal block replacement issues-p1000834.jpg   Terminal block replacement issues-p1000836.jpg   Terminal block replacement issues-p1000837.jpg
Old June 7th, 2008, 06:43 PM
ApplianceJunk's Avatar
Sounds like the burner switch is bad.
If you have another burner the same size on that stove you could plug that burner into one that you know works just to test the burner.
Old June 7th, 2008, 11:03 PM
Which burner is it, the large or small one? RF LF RR LR?
Old June 8th, 2008, 08:09 AM
Infinite Switch 2600w (Large Element) WB24T10029
icon
Infinite Switch 1500w (Small Element) WB24T10025
icon
Old June 8th, 2008, 10:16 AM
It's the LF small burner.
Out of curiosity, if the switch is bad and voltage is free-flowing to that burner, why isn't the burner hot? Could the bad switch have fried the burner element? If so, is there any risk of plugging that bad element into another receptacle for trouble shooting purposes?
Thanks for the feedback.
Old June 8th, 2008, 01:25 PM
The problem is your using that voltage pen.
The burner uses two hot lines, 240 Vac.
I would guess if you checked it with real volt meter you would find you only have 120 volts on one of the wires going to the burner.
This is what triggers your voltage pen, but yet it's not the voltage you need to make the burner heat.
Old June 9th, 2008, 11:19 AM
Thanks to everyone for all the input. Looks like I'll replace that switch and hope that does it. I imagine it's a pretty straight forward job.
Old June 9th, 2008, 04:51 PM
Ok, sounds good, let us know the outcome.
Old June 10th, 2008, 01:02 PM
Replacing that switch did the trick. Thanks to all for the guidance.
For anyone else attempting the same repair, please note that the Sears Parts website has the parts listed incorrectly, indicating that WB24T10025 is the 1500w switch. I suspect that's where redbeardnmt got his info in this thread. Here's the correct listing:
Infinite Switch 2600w (8"): WB24T10025
Infinite Switch 1500w (6"): WB24T10029
You can see from the photo below that part ending in 29 is the 1500w version. FYI.
Old June 10th, 2008, 01:43 PM
Glad to hear you got it repaired.
Thanks for the update.
Amana SZD26VW Water Filter Replacement and Other Issues bobage24 Amana 3 January 14th, 2008 10:53 AM
Amana ARTS6650E Control Panel Issues Blarg Amana 3 December 3rd, 2007 12:08 PM
Knocking during end of spin cycle soggypants Direct Drive Washers 7 June 12th, 2007 07:13 PM
Whirlpool range SF365PEGW burner ignition replacement parts mjdaniels2 Whirlpool 3 November 16th, 2006 08:01 PM
Jenn Aire cooktop switch replacement dfleming Maytag/Magic Chef/Admiral/Jenn-Air 0 November 11th, 2006 10:54 AM
