Results 1 to 10 of 12
Thread: freeze evap frozen
    breemak is offline Premium Member
    Jul 2008
    glendale az
    Unhappy freeze evap frozen
    I have a kenmore model 106.51259102 sxs and both sides are warm. I found that the evap coils are frozen up what can i check to find out what is wrong
    You would first want to put it into a defrost cycle, You have the adaptive defrost control board.
    This link shows you how to force it into defrost:
    http://www.applianceaid.com/adaptive_defrost.html
    Read were it says:
    For some Whirlpool refrigerators - some Kenmore refrigerators are made by Whirlpool ( 106.######## )
    If after a few minutes your defrost heater comes on, then you know the problem is in your adaptive defrost control board.
    Let us know what happens.
    Manufacturer part#2303822 is RepairClinic item#1058657
    2303822
    Jul 2008
    glendale az
    Question
    i did that it did defrost then i turned it back on and it started freezing up in less than 5 minutes so it should be the controller right???
    Yes, thats what you need then.
    Jul 2008
    glendale az
    Smile
    Jake I replace the defrost control and it start freezing up again but I am going to let it run its cycle to see what happens is that the correct thing to do
    ivoidwarranties is offline Appliance Tech
    May 2008
    on the frying pan
    don't forget you have to completely defrost evap coils- with hair dryer if necessary before running unit again. then, when compressor is running make sure freezer fan is also- sometimes intermittant fault, need to check occasionally when compressor running to see if consistantly working. my brands all need manual defrosting with hair dryer when evap's solid, timed defrost's don't get to the center of evap. the heater runs along edges of evap, if too much ice, won't melt all and it has a head start for more build-up.
    Jul 2008
    glendale az
    Question
    thanks I had the coiled defrosted with the hair dryer and it froze again i hav enever seen the evap fan run
    Its going have a thin layer of frost on it at all times, its just when that thin layer of frost builds-up to a think clog blocking the whole evaporator coil, because the Adaptive control board never cycled it through any defrost cycles.
    The evaporator fan should be running, try to turn the fan blade and see if it starts running, also feel the evaporator fan motor, to see if its hot.
    Jul 2008
    glendale az
    Question
    I can spin the fan freely but it does not keep spinning the motor part of the fan is not hot at all
    Ok, the next thing I would check to see is if your getting 120 volts to your evaporator fan motor when your compressor is running.
    If you have a volt meter, just put the meter probes on each terminal of your evap. fan motor to check it.
  1. Replies: 5
    Last Post: April 9th, 2008, 12:12 PM
  2. GE Freezer -evap motor fan?
    By redlady4850 in forum GE/Hotpoint
    Last Post: November 11th, 2007, 12:41 AM
  3. LG evap freezing over
    By rob223 in forum LG
    Last Post: October 30th, 2007, 08:31 AM
  4. Gss22kgmdww (frozen @ Room Temp)
    By maximus817 in forum GE/Hotpoint
    Last Post: October 23rd, 2006, 09:56 PM
  5. FRS24WSCB Evap Coil only partially cold
    By jjgoolsk in forum Frigidaire/Electrolux
    Last Post: October 10th, 2005, 08:58 PM
