July 13th, 2008, 09:18 PM
My dishwasher will not do anything at the moment. I'm fairly certain my thermal fuse needs to be replaced. I measured 120V at the input, but only millivolts on the output.
I see that the original part number 9269213 has been replaced by a new part number 8193762. It appears to come with a new harness, which from what I've read, should always be used. I don't have the kit yet, so maybe this will become clear once I have it, but I don't see any interconnects in my current wiring. I have a main that comes up, and it splits with one going to the fuse and the other to the control board. Here are a couple of links to the new part. Does the kit come with all I need to splice this into my current dishwasher?
http://www.repairclinic.com/referral...=1265&N=959376
http://www.searspartsdirect.com/partsdirect/searchByPartDescAction!searchByPartDescription.act ion?brandId=0582&productCategoryId=0130000&modelNumber=66517579201&backToLink=Return+to+Sub+Components&partDescription=fuse
Thanks in advance for your help.
Ned
July 13th, 2008, 11:01 PM
Hi Ned,
When its completely dead like that, then its likely your thermal fuse.
Here is a help link on this issue:
http://www.applianceaid.com/kadish2.html
You can ohm it for continuity with an ohm meter to see if it has no continuity. Thats what I always do.
Here's the thermal fuse for your model:
Manufacturer's Number: 8193762
8193762
Yes, its easy to change, it comes with complete instructions.
July 14th, 2008, 06:42 PM
Thanks for the quick reply. I'll be picking up the part tomorrow, and installing it after work. I'll post again after that.
July 14th, 2008, 10:35 PM
Sounds good Ned.
July 16th, 2008, 04:13 AM
All is well after replacing the thermal fuse.
July 16th, 2008, 07:21 AM
Excellent, good job fixing it Ned.
By janrog300 in forum Whirlpool/Roper
Last Post: September 29th, 2007, 11:25 PM
By chanchamone in forum KitchenAid
Last Post: July 9th, 2007, 09:55 AM
By BeccaSue in forum Sears Kenmore
Last Post: September 12th, 2006, 10:57 PM
By rebepany in forum Sears Kenmore
Last Post: March 16th, 2006, 06:56 PM
By tjs in forum Sears Kenmore
Last Post: December 20th, 2005, 05:16 AM
