Old July 14th, 2008, 10:19 AM
jpnk is on a distinguished road
Default Kenmore Coldspot SxS; 106.52254100; The Refrigerator seems to be running continuously Force-Defrost
Brand: Kenmore Coldspot SxS
Model Number: 106.52254100
Background of the problem....
It all started few weeks ago, the food in the Fresh Food section started freezing. I checked the temperature settings, they were set to #3 on both the freezer and fridge. I lowered the temperature settings to #2 on both the freezer and fridge and it worked, the fridge wasn't freezing the food.
However, I had the feeling that the refrigerator is running non-stop. I have noticed it not running occasionally, especially in the mornings. All of a sudden this Saturday, the fridge started warming up, no cold air coming through the Air damper/diffuser (First time this happened couple years ago and service engineer replaced it when it was still under protection plan), the freezer seemed to be OK but not.
I opened the back cardboard panel of the refrigerator; the compressor and the compressor fan were running, opened the front panel and dusted the condenser coil.
After reading one of your replies on this forum, I checked the back panel inside the freezer and noticed frost build-up. The evaporator coil was also completely covered with frost build-up. The evaporator fan was working just fine. As advised in another forum, I used the hair dryer to melt the frost build-up and put back the panel. Since last night the refrigerator is working fine, the cold air gets blown to the fridge. The only problem now is the refrigerator seems to be running continuously.
Any ideas of what could be the problem? Could it be the bad defrost timer or defrost thermostat or something else gone bad? Or am I just being paranoia?
Appreciate your help.
Regards,
JP
Old July 14th, 2008, 02:00 PM
Ok, you have a part thats out in your defrost system.
Its either:
1. Control board(listed below)
2. Defrost thermostat
3. Defrost heater
The way you can tell, is to force it in a defrost cycle. You should have a tech. data sheet in the bottom front behind the kickplate grill, it will tell you how to force it into defrost, if after a few minutes the defrost heater comes on, then we know its the control board thats bad.
Report back what you find.
Here's the control board for your model, in case you need to order it:
Manufacturer's Number: 8201527
8201527
Old July 15th, 2008, 06:15 AM
Default Need instructions
Hi Jake,
I did not find the instructions to force defrost. All I found was a circuit diagram when I pulled out the front grill. I'd appreciate if you can provide the step by step instructions to force defrost.
FYI, the Control board was replaced couple years ago along with the Air diffuser when the Fresh Food section was not cooling.
I also noticed the refrigerator did stop running at least 4 times in the last 24 hours.
Regards,
JP
Old July 15th, 2008, 09:00 AM
Hi JP,
Today's your lucky day, I remember someone posted the instructions a few years ago here, but I've been searching for it for a long time and I just found it.
To force a defrost cycle by following the instructions:
  1. Turn off the fridge using the control panel's ON/OFF button.
  2. Press ON/OFF and the water-filter Reset button for 3 seconds.
  3. Now the fridge is in Diagnostics mode at test #1.
  4. Defrost is the sixth test, so push the Reset button five times until the water-filter display reads "6".
Then give it a few minutes to see if the defrost heater comes on.
Old July 16th, 2008, 04:34 AM
Hi Jake,
Thanks for the instructions. I will try it and let you know the results.
There is no mechanical defrost timer in this refrigerator?
One more question, do I have to remove the back panel inside the freezer before forcing defrost?
Regards,
JP
Old July 16th, 2008, 06:58 AM
No, on your model its integrated into your control board I posted a link to above.
Just remove the freezer shelves, then take off the #18 screws here:
http://content.searspartsdirect.com/...5064-00009.png
Then the panel#17 will pull out.
Old July 20th, 2008, 08:16 PM
Hi Jake,
There is no display on the control panel (see the attached picture).
Still I followed the instructions and waited for about 10 minutes, nothing happened. Not sure if the forced defrost cycle really kicked in.
Evaporator coil had a little bit of frost build-up. Used the hair dryer to melt the frost build-up before putting back the panel.
Just to understand...
1. What would I see if the Forced Defrost actually kicks in.
2. How does the Defrost Heater look like on my unit.
Please advise on the next steps...
Regards,
JP
Kenmore Coldspot SxS; 106.52254100; The Refrigerator seems to be running continuously Force-Defrost-searskenmore_controlpanel.jpg
Old July 20th, 2008, 09:28 PM
Thats odd, was there a display of any lights on the control panel at all before this problem began?
I would say your control board is bad if nothing is lighting up on it, you can order it in the link I supplied in post#2.
The defrost heater would come on under the evaporator coil. You would see it get red hot, or feel heat coming from it.
#33 here is your defrost heater:
http://content.searspartsdirect.com/...5064-00011.png
Here's the defrost heater for your model:
Manufacturer's Number: 2188174
icon
icon
icon2188174
Old July 21st, 2008, 11:40 AM
Hi Jake,
The lights on the control panel are all working fine. The picture was taken while the Refrigerator was turned Off.
I meant the control panel on my refrigerator doesn't have any number display on it.
Regards,
JP
Old July 22nd, 2008, 12:36 AM
I'm not sure I'm following you, no lights in the display when you did the test? But display light works fine otherwise?
Tags
106.52254100, kenmore coldspot sxs, non-stop, running continuously
LinkBack to this Thread: http://www.applianceblog.com/mainforums/sears-kenmore/13587-kenmore-coldspot-sxs-106-52254100-refrigerator-seems-running-continuously-force-defrost.html
Posted By For Type Date
Sears Kenmore on Appliance Blog Forums | BoardReader This thread Refback September 12th, 2009 07:12 AM
Kenmore SXS Coldspot 106.54582400 -- freezer & fridge not cold, icemaker not working NH Mom of 3 Sears Kenmore 19 December 4th, 2008 09:50 PM
Kenmore coldspot sxs intermittent ice eject Wadel Sears Kenmore 5 September 12th, 2007 05:19 PM
Kenmore Coldspot 106.57572790 SxS Relay? Waz Sears Kenmore 5 July 17th, 2007 07:29 AM
Kenmore Coldspot 106.50592003 SxS - Freezer Not Freezing RBF Sears Kenmore 8 April 4th, 2007 08:43 AM
