Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Kenmore 790.9661 Oven Elements Don't Heat
    AugustLeo is offline Premium Member
    Jul 2008
    Rhode Island
    Default Kenmore 790.9661 Oven Elements Don't Heat
    I've searched this forum for tips and answers and am asking for confirmation concerning my situation:
    1. Kenmore 790.96614400 Electric Range 4 years old
    2. The range is receiving 240 volts at the power terminal strip
    3. Everything but the oven elements work fine
    4. No error codes
    5. Broiler element measures 14 ohms and 32 volts across the terminals
    6. Oven element measure 17 ohms and 35 volts across the terminals
    From what I've read, this sounds like the Electronic Oven Control (EOC) unit.
    If that's correct, where can I buy a replacement and at what cost.
    Thanks for your help.
    Michael
    shadowrider is offline Premium Member
    Mar 2008
    Louisville,Ms
    Hi, I've got the same problem with a Kenmore #790.96011401. Bake unit went out, burned really bad, and the owner installed new element. Range will work on broil, but not bake. No fault codes, no 240 volts to bake element. Everything else works. I'm thinking EOC. Any other ideas? Thanks.
    Quote Originally Posted by AugustLeo View Post
    4. No error codes
    Michael
    Hi Michael,
    Yes, your broil & bake elements ohm out fine, so its likely your EOC.
    Here's the cheapest one I found for your model thats in stock that you can order:
    Manufacturer's Number: 316418702
    icon
    Quote Originally Posted by shadowrider View Post
    Hi shadowrider, your model uses a different EOC part# than Michael's.
    Here's the cheapest one I found for your model thats in stock you can order:
    Manufacturer's Number: 316418208
    Jul 2008
    Rhode Island
    Thanks Jake.
    I ordered the part you recommended. I believe it is returnable if it doesn't fix the problem (is that true?)
    I'll let you know how it turns out and thanks again.
    Michael
    Mar 2008
    Louisville,Ms
    Thanks Jake, I'll check with my customer and see what he wants to do.
    Thanks Jake.
    Michael
    Yup Michael, you have a full 30 day full refund if it doesn't fix the problem and you need to return it.
    Sounds good shadowrider.
    Jul 2008
    Rhode Island
    Works great, Jake. Easy to install too. Thanks again!
    Excellent, good job fixing it Michael.
  1. Replies: 9
    Last Post: May 14th, 2011, 08:37 AM
  2. Kenmore 790.95683302 - oven doesn't heat up
    By pkcom in forum Sears Kenmore
    Last Post: March 14th, 2008, 09:45 AM
  3. Kenmore Oven Won't Heat
    By bd7 in forum Sears Kenmore
    Last Post: November 12th, 2007, 10:52 PM
  4. Kenmore gas oven slow to heat up
    By t7044wa in forum Sears Kenmore
    Last Post: November 6th, 2007, 04:43 PM
  5. Kenmore 911.93261690 oven won't heat
    By duaned53172 in forum Sears Kenmore
    Last Post: September 26th, 2006, 10:50 AM
