Old July 21st, 2008, 11:17 AM
AugustLeo is on a distinguished road
Default Kenmore 790.9661 Oven Elements Don't Heat
I've searched this forum for tips and answers and am asking for confirmation concerning my situation:
1. Kenmore 790.96614400 Electric Range 4 years old
2. The range is receiving 240 volts at the power terminal strip
3. Everything but the oven elements work fine
4. No error codes
5. Broiler element measures 14 ohms and 32 volts across the terminals
6. Oven element measure 17 ohms and 35 volts across the terminals
From what I've read, this sounds like the Electronic Oven Control (EOC) unit.
If that's correct, where can I buy a replacement and at what cost.
Thanks for your help.
Michael
Old July 21st, 2008, 08:24 PM
shadowrider is on a distinguished road
Hi, I've got the same problem with a Kenmore #790.96011401. Bake unit went out, burned really bad, and the owner installed new element. Range will work on broil, but not bake. No fault codes, no 240 volts to bake element. Everything else works. I'm thinking EOC. Any other ideas? Thanks.
Old July 22nd, 2008, 11:52 AM
4. No error codes
Michael
Hi Michael,
Yes, your broil & bake elements ohm out fine, so its likely your EOC.
Here's the cheapest one I found for your model thats in stock that you can order:
Manufacturer's Number: 316418702
icon
Old July 22nd, 2008, 11:55 AM
Hi shadowrider, your model uses a different EOC part# than Michael's.
Here's the cheapest one I found for your model thats in stock you can order:
Manufacturer's Number: 316418208
AugustLeo (July 22nd, 2008)
Old July 22nd, 2008, 01:56 PM
Thanks Jake.
I ordered the part you recommended. I believe it is returnable if it doesn't fix the problem (is that true?)
I'll let you know how it turns out and thanks again.
Michael
Old July 22nd, 2008, 07:03 PM
Thanks Jake, I'll check with my customer and see what he wants to do.
Old July 23rd, 2008, 12:50 AM
Thanks Jake.
Michael
Yup Michael, you have a full 30 day full refund if it doesn't fix the problem and you need to return it.
Old July 23rd, 2008, 12:51 AM
Sounds good shadowrider.
Old July 27th, 2008, 09:59 AM
Works great, Jake. Easy to install too. Thanks again!
Old July 27th, 2008, 10:01 PM
Excellent, good job fixing it Michael.
Sears Kenmore 790.92889301, oven won't heat, stovetop & clock fine! help... kgollnick Sears Kenmore 8 December 14th, 2008 10:34 AM
Kenmore 790.95683302 - oven doesn't heat up pkcom Sears Kenmore 3 March 14th, 2008 10:45 AM
Kenmore Oven Won't Heat bd7 Sears Kenmore 8 November 12th, 2007 11:52 PM
Kenmore gas oven slow to heat up t7044wa Sears Kenmore 5 November 6th, 2007 05:43 PM
Kenmore 911.93261690 oven won't heat duaned53172 Sears Kenmore 2 September 26th, 2006 11:50 AM
