Old July 22nd, 2008, 08:41 AM
SD Paul is on a distinguished road
Default Gas Kenmore dryer 110.78942892 no heat
This is probably similar to questions already asked and answered, but I don't know what model numbers are similar to mine. I can't find any references to my exact model number, but I can lookup parts on repairclinic.com just fine.
I have a gas Kenmore model 110.78942892 and everything seems to work fine except there is no heat. This was a sudden change from one day to the next, not a gradual change.
Are there any similar manuals available with diagnostics covering this model? Looking at the parts list there are several obvious things which could potentially cause this (igniter, gas valve solenoid, venting, etc), but I am not sure how to test the components and in what order.
Paul
Old July 22nd, 2008, 05:38 PM
Hi Paul,
The most common part to go out in gas dryers is the gas coils.
Here's a help link that explains what to test, and a guide to access the gas coils:
http://www.applianceaid.com/gas_dryer.html#noheat
Having a volt/ohm meter is a must for testing.
Here's the gas coil kit for your model:
Manufacturer's Number: 279834
279834
Old July 26th, 2008, 05:59 PM
Default Failing the first test.
Thanks for the reply. I am failing the very first test, which is to check that I have 110 at the first connector in the very front of the unit that leads first to the coils.
Unfortunately, that step is assumed to pass, and there are no further diagnostics for that! I assume that is a problem with a timer or controller board?
My next dumb question is where to find instructions for cracking the controller assembly. I can pop the top of the dryer off and pivot it backwards, but it is not obvious how the head comes apart. There were some screws through a sheet metal piece on the back, but removing them didn't seem to loosen anything. The head itself is screwed onto the dryer top with the screw heads inside the head, so obviously it was mounted before the head was closed up.
Paul
Old July 27th, 2008, 10:59 AM
Hi Paul,
#59 here:
http://content.searspartsdirect.com/...0225-00003.png
is your thermal fuse, its white and it mounts on your blower wheel housing.
Here's the thermal fuse for your model:
Manufacturer's Number: 3390719
If your not getting 110 volts to the first connector, then its possible the thermal fuse is blown, you can jump it just to test for 110 volts, or ohm it for continuity with the dryer unplugged.
You mean getting into your console assembly on top of your dryer?
Read #20 here:
http://www.applianceaid.com/whirlpool-dryers.html
Old July 27th, 2008, 12:27 PM
Unhappy
Thanks! The thermal fuse is indeed open, so I will replace that as the first step.
When I took off the duct/enclosure that the lint trap slides into to reach the thermal fuse, I was amazed at how much lint and sand was in there. It was at least half constricted, so it was good that I had to open that up.
Also, in the light of day (instead of late at night) I was able to get into the head. That turned out to be a good thing to do as well, because of course that is where the stuck the schematics and diagnostic sheets. They came with a nice diagram that showed how the head goes together. That was not entirely helpful at that point, since it was already open!
Old July 27th, 2008, 10:08 PM
Excellent, good job finding the thermal fuse was open Paul.
Keep us updated when you finish.
Old July 30th, 2008, 01:26 AM
Default Success!
The thermal fuse arrived today from AppliancePartsPros. Less than five minutes to swap it out, and the dryer is good as new!
Thanks for the good advice. This site is a great resource.
Paul
Old July 30th, 2008, 10:10 AM
Excellent Paul, good job fixing it.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/sears-kenmore/13633-gas-kenmore-dryer-110-78942892-no-heat.html
Posted By For Type Date
Gas Kenmore dryer 110.78942892 no heat This thread Refback October 18th, 2009 09:52 AM
Sears Kenmore Gas Dryer Model No. 417.93042202 does not heat dougefresh Sears Kenmore 14 May 18th, 2008 07:33 PM
Kenmore 80 Gas Dryer heats up and then heat stops.. why? tone_p Sears Kenmore 1 October 22nd, 2007 11:15 PM
Kenmore Elite HE3 Gas Dryer No Heat billjes Sears Kenmore 1 June 26th, 2007 10:27 AM
Kenmore 70 series gas Dryer not heating right pflowers Sears Kenmore 1 February 12th, 2007 09:14 PM
Kenmore 80 Series Gas Dryer Heat Problem rcforten Sears Kenmore 1 December 13th, 2006 01:28 AM
