Results 1 to 10 of 11
Thread: [FIXED] Kenmore Series 80 doesn't fill - 110.27822790
    mikesixtysix is offline Premium Member
    Jul 2008
    Morristown, NJ
    Default [FIXED] Kenmore Series 80 doesn't fill - 110.27822790
    At first it was intermittent, and just fiddling with the knobs a few times would get it to fill. Now, it doesn't fill at all. In fact, it starts agitating right away. I assume this means that there is something wrong with the water level sensor? Any suggestions are appreciated.
    Jul 2008
    Morristown, NJ
    Took the cabinet off, but not sure what I'm looking at... I see a clear tube right side in the back (if looking at the unit from the front)... hmm. a little help?
    When you move your water level knob to reset does it start filling with water?
    If so, then the problem is in your water level switch, here's the cheapest one I found for your model:
    Manufacturer's Number: 3366847
    icon
    icon
    icon3366847
    Jul 2008
    Morristown, NJ
    Adjusting the water level knob has no effect, it won't fill no matter what settings are selected. It immediately starts agitating when it's turned on.
    What is the part that actually detects the water level? Perhaps that's what has gone bad...
    The part I linked to above is your water level switch that tells it to put water in then start agitating. But I've also seen the timer do this as well.
    Take the clear rubber tube off the water level pressure switch and blow through the nipple on the water level pressure switch and you should hear it click. If no click sound then thats the problem, your water level switch. Then you can order a new one from that link above.
    Jul 2008
    Morristown, NJ
    I heard something, but definitely not a click. I'm going to replace this part... I'll let you know how it goes.
    Ok, sounds good, yes, let us know how it goes.
    Jul 2008
    Morristown, NJ
    It worked! Awesome! Thanks Jake, you are the man!
    Excellent Mike, good job fixing it.
    Jul 2008
    Morristown, NJ
    the wife was saying, "just buy a new one"... but i'm glad i checked here first. i don't think they make them like they used to anymore, hopefully i'll get some more good years out of this old girl.
    thanks jake
  1. Kenmore 70 Series leaks during fill
    By cogo162 in forum Sears Kenmore
    Last Post: March 19th, 2008, 10:22 AM
  2. Replies: 0
    Last Post: November 5th, 2007, 08:11 AM
  3. Kenmore 70 Series - tub won't fill
    By mbckmyr in forum Washers
    Last Post: April 1st, 2007, 11:12 AM
  4. Kenmore 70 series 11022722100 doesn't fill
    By mike56p in forum Sears Kenmore
    Last Post: January 1st, 2007, 08:32 PM
  5. Kenmore 80 series won't fill...
    By thegreatoz in forum Sears Kenmore
    Last Post: August 27th, 2005, 07:42 AM
