At first it was intermittent, and just fiddling with the knobs a few times would get it to fill. Now, it doesn't fill at all. In fact, it starts agitating right away. I assume this means that there is something wrong with the water level sensor? Any suggestions are appreciated.
Thanks! Last edited by mikesixtysix; July 27th, 2008 at 09:30 PM.. |
Took the cabinet off, but not sure what I'm looking at... I see a clear tube right side in the back (if looking at the unit from the front)... hmm. a little help?
When you move your water level knob to reset does it start filling with water? If so, then the problem is in your water level switch, here's the cheapest one I found for your model: Manufacturer's Number: 3366847 Jake |
Adjusting the water level knob has no effect, it won't fill no matter what settings are selected. It immediately starts agitating when it's turned on.
What is the part that actually detects the water level? Perhaps that's what has gone bad... Last edited by mikesixtysix; July 28th, 2008 at 09:56 AM.. |
The part I linked to above is your water level switch that tells it to put water in then start agitating. But I've also seen the timer do this as well.
Take the clear rubber tube off the water level pressure switch and blow through the nipple on the water level pressure switch and you should hear it click. If no click sound then thats the problem, your water level switch. Then you can order a new one from that link above. Jake
I heard something, but definitely not a click. I'm going to replace this part... I'll let you know how it goes.
Thanks! |
Ok, sounds good, yes, let us know how it goes.
It worked! Awesome! Thanks Jake, you are the man!
Excellent Mike, good job fixing it.
the wife was saying, "just buy a new one"... but i'm glad i checked here first. i don't think they make them like they used to anymore, hopefully i'll get some more good years out of this old girl.
thanks jake |
| Kenmore 70 Series leaks during fill | cogo162 | Sears Kenmore | 3 | March 19th, 2008 11:22 AM |
| water level measurements - kenmore 80 series 110.27822790 | idover | Sears Kenmore | 0 | November 5th, 2007 09:11 AM |
| Kenmore 70 Series - tub won't fill | mbckmyr | Washers | 1 | April 1st, 2007 12:12 PM |
| Kenmore 70 series 11022722100 doesn't fill | mike56p | Sears Kenmore | 3 | January 1st, 2007 09:32 PM |
| Kenmore 80 series won't fill... | thegreatoz | Sears Kenmore | 1 | August 27th, 2005 08:42 AM |
