When we moved into our house the previous owners left a Kenmore range. After cleaning it up, both the range and the oven were working.
However, now on the range is working and the oven will not turn on. Would it be the igniter? If so, what are the next steps to getting it fixed?
Many thanks, Jillian |
Hi Jillian,
Whats the model# of your range? Yes, it sounds like the oven glow bar igniter, do you see it glow orange in the bottom of your oven when you turn it on? but no gas comes out? Jake
Where do I find the model number? When I looked on the door on the side there seems to be a metal tag, but it's too worn for me to make a number out. Would it be on the back as well?
I will check to see what happens when I turn it on.
It should be located on the very bottom front frame after you pull out your storage drawer.
Kenmore 362.72295790
When I turn it on, nothing happens. No glow or heat.
Hi Jillian,
The way I test it is put my volt meter leads in that connector that goes to your oven igniter glow bar, when the oven is on you should get 120 volts on the volt meter. If you do and the igniter glow bar isn't coming on, then you have a bad oven igniter glow bar. If you don't have a volt meter, you can get a cheap one at Radio Shack. To get access to the oven igniter glow bar electrical connector, I take out the bottom storage drawer completely then get a flashlight or floodlight to see under there, and then I can see the oven igniter glow bar connector. Here's the oven igniter glow bar for your model in case you need to order it: Manufacturer's Number: WB13K21 Let us know how it goes. Jake |
| Tags |
| igniter, kenmore range, oven not working |
| Kenmore slidein range installation problem | thulb | Sears Kenmore | 3 | November 21st, 2007 10:41 AM |
| Kenmore 790.75711891 Range Lock Light Flashing | cmsedlak | Sears Kenmore | 1 | August 18th, 2007 11:24 PM |
| Kenmore Model No. 665.9200 electric range | opusfly69 | Sears Kenmore | 3 | March 7th, 2006 11:23 PM |
| Slow Preheat with Kenmore Electric Range | bigredrocket | Sears Kenmore | 1 | January 22nd, 2006 02:18 PM |
| Intermittent Kenmore Range Operation | tex9999 | Sears Kenmore | 3 | August 10th, 2005 10:00 PM |
