Results 1 to 6 of 6
Thread: [FIXED] Kenmore Dishwasher 665.1383 not cleaning
    toolbox granny is offline Premium Member
    Jan 2009
    Virginia
    Default [FIXED] Kenmore Dishwasher 665.1383 not cleaning
    Hi, Jake. Toolbox Granny here with her first post. We have always bought Whirlpool products under their brand or Sears Kenmore. The older appliances lasted forever (15 years minimum) and needed little or no repairs. All of our major kitchen appliances have reached the age where the repair cost outweighs replacement.
    We bought a Sears Kenmore Ultra Wash dishwasher 665.13834K600 ($683.98)installed November 2006. Initially we were very pleased with how quiet it was. There are only two of us and we run the thing once or twice a week. About six months ago we noticed that sometimes the dishes top and bottom were not clean and had a dried-on grit and larger pieces of food on them, particularly the glasses on the top rack. The problem seems to have gotten worse over time.
    I’ve been reading through some of the existing posts about the gritty residue problem. I noticed that the flapper on the top opening of the feed tube to the top rack stays open when I pull out the rack. We use it almost exclusively in that position.
    Today, I ran the Smart Wash cycle with only the top rack in and filled with dishware and they were still soiled. I then ran just the Quick Rinse, during with I opened the door to check to see if the spray arm was spinning. I didn’t appear to be, which could indicate that water isn’t being pumped up high enough because the bottom flapper of the feed tube does appear to be closed. I also noticed food particles floating in the water on the bottom of the dishwasher. The strainer doesn't appear to be particularly clogged.
    So, does this sound like the more expensive pump motor replacement, or the simpler and less expensive chopper/flapper replacement? Do you have other diagnostic tests for me to run? Is there a repair site specific to my model that I can read though and decide if it’s something I feel comfortable tackling? If I have to pay for a repair I don't want to give Sears any more money. Can any reputable repair shop get the parts and make the repair?
    It bites me that this lightly-used, 2-year-old dishwasher would need a repair this soon. Is it foreign parts and labor that makes the newer models more vulnerable to repairs and would I just be replacing inferior parts with more inferior parts that will need replacing in another 2 years? Should I switch to a manufacturer with better quality control – if one exists?
    Thank you for your patience with my questions/venting.
    Toolbox Granny
    Hi Toolbox Granny,
    The first thing you want to check is your chopper screen blade assembly and check valve.
    Yes.
    This is very uncommon for yours to do this if you don't use it that often like you say.
    http://www.applianceblog.com/manuals/pointvoy8178022.pdf
    Page 17 Read 1-4 where it says this:
    Lower Spray Arm
    It shows how to get access to the chopper screen and check valve.
    Jan 2009
    Virginia
    Hello, again, Jake.
    Thanks for your prompt response. I finally got the courage to start pulling apart the dishwasher to the point of removing the chopper assembly and check valve (both of which look fine). I found all sorts of debris - olive pits, oyster shell, grape stem. But most interesting is what I didn't find. Is the Kenmore supposed to have a Foreign Object Protector? Page 21, item 3, fig. 3-21 instructs to remove it. I see a post where I assume the screw would go, but no protector, which might explain the amount of debris I found inside and outside of the inlet protector. If not, I'll attempt to put the thing back together and keep my fingers crossed. If so, I'll get the part and install it with the rest of the pieces and see what happens.
    After slightly over two years out, what do you think the response would be if I go back to Sears and ask them to send me the part gratis since it was missing (if this is so) to begin with? In the meantime I will lecture grandaddy about keeping his pits and other hard bits out of the dishwasher.
    Thats odd, I don't even see it on the parts diagram either:
    http://c.searspartsdirect.com/lis_pn...7088-00008.png
    Maybe on this model it doesn't come with one.
    Jan 2009
    Virginia
    A very grateful toolbox granny, here. I was able to put all the pieces back together with nothing left over! We've run the dishwasher now at least half a dozen times and the dishes were clean - no grit or residue. Thanks for your guidance on this - well worth the $5.00 subscription.
    Excellent, good job fixing it Toolbox Granny.
  1. Replies: 2
    Last Post: June 18th, 2010, 01:02 PM
  2. Kenmore dishwasher fills but won't wash
    By lgmccoy1 in forum Sears Kenmore
    Last Post: February 26th, 2008, 10:24 AM
  3. Replies: 1
    Last Post: February 13th, 2007, 11:38 PM
  4. Kenmore 665.15899100 dishwasher
    By jdoane3414 in forum Sears Kenmore
    Last Post: December 30th, 2005, 11:51 AM
  5. Kenmore 665 Dishwasher Cycle Completion
    By apotter in forum Sears Kenmore
    Last Post: May 3rd, 2005, 08:49 AM
