I have a 2 yrs oldKenmore 790.9621340C ceramic glass cook electrical range that's having problem.
The inner burner on the R-F dual burner has stopped heating, the outter burner is working fine. When the knob is turned, the light does indicate it is on but the inner burner simply will not heat up. I have taken the 2 screws holding the ceramic top in place off and pivot the top to take some measurements. I think the R-f element is getting voltage but not sure why it's not heating up. |
That inner burner element may have a small fracture/break in it, causing it not to come on when voltage is applied to it. Here's the R-F element for your model: Manufacturer part number 316418401 is RepairClinic item number 1197059 316418401Jake
Jake, thanks for the quick reply. My hunch is also telling me it's the radiant element that's broken.
BTW, do you know where I can find the wiring diagram for the radiant element?? I would like to know what each wires are for just I can understand how the radiant element work. There are a total of 5 wires for the dual radiant element, 1 is black which I assume it's ground, the other 4 wires, am I correct to assume 1 is for the small burner and the other is for the big burner and the 2 remaining are for ohm/resistance adjustment? |
Unfortunately Sears doesn't make their wiring diagrams available online, it should have come with your owners manual when you purchased the range.
| Kenmore 665.95802000 LF burner problem | dshedd | Sears Kenmore | 1 | March 1st, 2008 12:46 PM |
| Kenmore 70 series gas Dryer not heating right | pflowers | Sears Kenmore | 1 | February 12th, 2007 07:14 PM |
| Kenmore 665.16791791 water heating slow? | haus | Sears Kenmore | 3 | January 16th, 2007 09:01 PM |
| Kenmore Range model 911.95575 burner out | mars1947 | Sears Kenmore | 2 | July 31st, 2006 04:37 PM |
| Kenmore Elite 665-17469300 heating element split | aniwayne | Sears Kenmore | 9 | September 26th, 2005 08:41 PM |
