Old March 2nd, 2009, 08:30 AM
Bigfoot100 is on a distinguished road
Question Kenmore Elite - New Humming Noise
Hey Now - We have a Kenmore Elite Model 665.16699 Dishwasher, and several days ago it started making a humming noise when it is washing.
I removed the kick panel below the door, and can hear the noise is coming from the bottom of the dishwasher. From inside, I removed the lower spinning spray arm, then removed the screen thing and cleaned the screen and the gunk and stuff that was below it. I did find a small rubber foot in there, and figured that must have been causing the noise. But now it's all back together and the noise has not changed.
Any suggestions?
Old March 2nd, 2009, 09:39 AM
Its possibly the motor assembly.
You'll likely need to pull the motor out from the sump and check it.
Page 17 Read 1-4 where it says this:
Lower Spray Arm
Here's the motor assembly for your model:
8534942
Old March 2nd, 2009, 10:20 AM
Thanks for the quick reply, Jake!
The manual at that link doesn't match up with my unit. The full part number for my unit is:
66516699200
According to Sears Parts Direct, the p/n for my motor is:
8535760
Do you think I can follow the instructions in that manual anyway, or is there another manual for my unit? This unit has the "concealed" control panel along the top edge of the door. When I bought it I was pretty sure that it was made by KitchenAid...
Thanks again,
John
Old March 2nd, 2009, 07:49 PM
No John, 8535760 is the motor, but you need the motor assembly which Includes volute, shaft seal, and impeller.
Trust me.
That repair manual is identical to yours, all Kenmore dishwashers starting with the model# 665. are made by Whirlpool.
Old March 3rd, 2009, 06:09 AM
Wink
Jake - Last night I was looking thru the manual and realized that the guts do in fact look like mine. I was going to send a follow-up, but you beat me to it!
Anyway, you're right, and I'll go ahead and use this manual to get the motor out and take a look.
Thanks a lot!!!
John
Old March 3rd, 2009, 09:11 AM
Yes, the inside guts are identical.
Old November 22nd, 2009, 08:36 AM
bscritch is on a distinguished road
I have the same issue, but can't access this link....gives me a page not found error.
thanks!
Lower Spray Arm
8534942
Old November 22nd, 2009, 09:10 PM
Ok,
Here's the repair manual link:
www.applianceblog.com/manuals/pointvoy8178022.pdf
Old November 23rd, 2009, 07:21 AM
Thanks Jake....plan on diggin in to this tonight. I have a Kenmore elite 665.137XXX and as soon as it fires up, it has a very annoying hum to it. Getting close to the DW, the hum appears to be lower right corner....and it hums the entire time that it's on.
I was going to start with the chopper and ensure nothing is amiss there....your thoughts??
Great website...thanks a lot!
Brian
Ok,
Old November 23rd, 2009, 08:47 AM
Hi Brian,
Can you post the complete model# of your dishwasher? The model# tag is located inside the door on the left or right side tub frame.
Does it do the same hum sound when you press the cancel button?
Kenmore Elite Calypso 110.22082100 whining noise during spin tub fills with water CBricker Sears Kenmore 1 September 2nd, 2007 10:35 PM
Kenmore Elite Does not agitate, no noise Stan Jett Sears Kenmore 5 February 6th, 2007 03:39 PM
Kenmore ELite 596.75523400 Making "GRINDING" noise Jclarke Sears Kenmore 1 October 8th, 2006 08:57 PM
Kenmore Elite HE3 F11 & noise ftna1 Sears Kenmore 4 November 27th, 2005 05:31 PM
Kenmore 90 series loud humming motor noise Trixiea Sears Kenmore 1 September 27th, 2005 11:00 PM
