I have checked the drain hose at both ends including garbage disposal entry and no clog. Replaced check valve. As we thoroughly rinse all dishes before placing into washer I would think unlikely that any debris inside unit around impeller/pump assembly. When running Cancel/Drain function unit runs and sounds normal although just circulates dirty water which ends up on otherwise dry dishes. Is there a solenoid that controls drain function that may be bad as friend suggests? Where located and do you have part number? Do not have owners manual and no errors on display. Thanks.
Here's the diagram for your motor/pump assembly: http://c.searspartsdirect.com/lis_pn...4096-00004.png If your check valve is ok and not clogged, then its likely your drain impeller#24 is bad. They have a repair kit with instructions to change both the drain impeller and wash impeller#11 you can order here: Here's the impeller kit for your model: Manufacturer part number 675806 is RepairClinic item number 679717 675806Jake
Thank you Jake, I am going to pick up the kit now. Am I able to access and disassemble all from from inside the machine or will I need to pull out entirely and go in from bottom of machine on its side?
Sounds good, you can do it all from inside the machine.
Hi Jake, replaced the drain/wash impeller kit and no luck, still does not drain. Upon inspection no kit parts looked bad. At this point had also previously replaced check valve. What do you suggest next? Again, no error codes display. Thanks.
Did you take the drain hose off from the garbage disposal and get a bucket to see if it drains in that when its running in the drain cycle?
Because it sounds like everything is clear inside the pump, so that would just leave the drain hose or the garbage disposal clogging it, and believe it or not, I've seen both clog and cause a NO drain issue. If it still doesn't drain in the bucket, then take off you drain hose and blow through that or run water through it to make sure thats not clogged. Jake
| 665.17033402 Kenmore Dishwasher won't drain | sjtm98 | Sears Kenmore | 1 | November 7th, 2007 01:20 PM |
| Kenmore Dishwasher won't drain | parrotheadlois | Sears Kenmore | 10 | December 20th, 2006 11:12 AM |
| Help My Kenmore Dishwasher won't Drain | lacrue79 | Sears Kenmore | 2 | August 4th, 2006 05:34 PM |
| Kenmore dishwasher 665.15929001 won't drain | distressed_kenmore_user | Sears Kenmore | 3 | September 5th, 2005 09:19 AM |
| Another Whirlpool Dishwasher won't drain | rickm | Whirlpool | 1 | August 8th, 2005 10:11 PM |
