Results 1 to 10 of 11
Thread: [FIXED] Kenmore Series 90 Dryer stops after 10-20 minutes of drying
    kreiner is offline Premium Member
    Apr 2009
    Michigan
    Unhappy [FIXED] Kenmore Series 90 Dryer stops after 10-20 minutes of drying
    Need some help here. I have a Kenmore Dryer model number 110.66902691
    When I start a drying cycle the dryer will start and seem to run fine for 10-20 minutes. Then it will quit. It will not restart, but it will buzz when the start button is pressed. If I wait overnight, it will start again, but run only a few minutes again before shutting down. Any instructions of what to check and how to access it would be very much appreciated.
    Kevin
    Hi Kevin,
    Everything comes out through the front, here's a link to show you how:
    http://www.applianceaid.com/whirlpool-dryers.html#four
    Sounds like your motor is bad.
    Here's how to change the motor and shows how to take off the blower wheel:
    http://www.applianceaid.com/279787.html
    Here's the for your model you can order:
    Manufacturer's Number: 279787
    279787
  3. The Following User Says Thank You to Jake For This Useful Post:
    kreiner (April 20th, 2009)
  4. #3
    Apr 2009
    Michigan
    Smile Thanks
    Thanks. I had a thought it might be the motor. My wife thought maybe a fuse since her mother described something similar and said it was a fuse in her dryer. But after reading posts on this site it sounded to me like any fuse that went out would cause the dryer not to function at all.
    I just ordered the part. Thank you for directing me to a place I could get it for even less then your site.
    Thank you as well for the link to the instructions. I will post again if I have any more questions when the motor comes and when the project is complete.
    Kevin
  5. #4
    Yes Kevin, if it was the thermal fuse, then the dryer wouldn't come on at all.
    Yes, the new motor should fix it.
  6. #5
    Apr 2009
    Michigan
    Question can't loosen motor from blower
    Jake, or whomever can help me:
    The instructions you linked me to have been okay so far (except I had a few more screws to loosen than the instructions indicated). But I have run into a snag. The instructions say in order to loosen the motor from the blower a 1/2 inch socket extension is used. I do not have that size of sockets. I have tried various other methods to try and loosen the motor from the blower. All I have to show for it though are a few bruises, including me ego. Any thoughts about any other methods I can use to unscrew the motor from the blower?
    Kevin
  7. #6
    Apr 2009
    Michigan
    Default some pictures
    Here are some pictures that show where I am at and how the motor is connected to the blower.
    Here is an overview shot of where I am at:
    Here is top view of how the motor connects to the blower
    Here is the front of the blower unit. The hole in the center is where I was supposed to put the 1/2 inch socket extension.
    And a close up of the front of the blower showing how I mangled the "square" hole a bit as I tried different methods to keep the blower from turning while I used a pipe wrench on the pulley end of the motor.
    Thanks for any help you can give me so I can get the motor separated from the blower.
    Kevin
  8. #7
    Ok Kevin,
    I was going to mention that sometimes that blower wheel is really on your motor shaft to stay, unfortunately.
    I've had a few I've had to break off and get a new blower wheel.
    Jetdoctor1 used a drill on his and it worked:
    [FIXED] kenmore dryer front load mod 110.63032101 wont dry
    Yes, its a hell of a job if that blower wheel won't come off, don't let it get you down, you will get it!
    Here is a new blower wheel for your model:
    Manufacturer's Number: 697772
    icon
    icon
    icon
  9. #8
    Apr 2009
    Michigan
    Cool one more thing
    First, I must tell you, I got the motor in one day!!! And only paid for standard shipping!! Thanks! I was greatly and pleasantly surprised.
    Well, I got the blower disconnected from the motor. You inspired me to try harder! I don't think it broke either, because I got the new motor on and screwed the blower wheel onto the motor. It seems tight to me.
    Here is the one possible problem: I had trouble getting the second clip off the motor (the one that holds it down). It broke on me. here is what it looks like:
    Do I have to use both clips to hold the motor down? And if so, where can I get one?
    It felt so good to get that blower unscrewed successfully, only to have that clip break on me. Now, I suppose I'll have to wait a couple days before I can put the dryer back together. And I was so hopeful I could surprise my sleeping wife (as if she could get any decent sleep with me right outside the bedroom door with the shop vac roaring and me banging the sides of the dryer with pipe wrenches).
  10. #9
    Yup Kevin, thats happened to me too a few times, but not as much as the blower wheel not coming off.
    Yes, its best to have both good clamps on the motor, just to be on the safe side.
    Here's the motor clamp for your model you can order:
    Part Number: AP3133895
    icon
    icon
    icon
    Or if you live near Canton, MI. you can pick it up tomorrow here:
    RepairClinic.com
    48600 Michigan Avenue
    Canton, MI 48188-2242
  11. The Following User Says Thank You to Jake For This Useful Post:
    kreiner (April 21st, 2009)
  12. #10
    Apr 2009
    Michigan
    Unfortunately, I live too far from Canton to make the trip. But I decided that to surprise my wife was the most important thing. I straightened the clamp as well as I could and put the broken side on first and the other side was just as hard to snap on as the good clamp. It looked and felt secure; the clamp wasn't moving and the motor was pretty stable. So I put the whole thing back together and tried it out and it worked! It is hard to believe that in only 40 hours I went from broken down dryer, finding your site and paying only 5 bucks to get such great help and fixing the dryer myself (never had opened one up before). A big thanks to you!
  1. Kenmore Series 70 Dryer starts, then stops
    By bmeeks in forum Sears Kenmore
    Last Post: June 16th, 2008, 03:49 PM
  2. Duet Dryer stops drying after 15 minutes
    By wrobins in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 14th, 2007, 01:10 PM
  3. Kenmore 70 series stops after 10 minutes
    By Cubby007 in forum Sears Kenmore
    Last Post: October 28th, 2006, 08:36 PM
  4. Replies: 3
    Last Post: December 10th, 2005, 03:07 PM
  5. Kenmore Dryer Stops after 10 minutes of drying
    By elvisbetha in forum Sears Kenmore
    Last Post: June 30th, 2005, 10:29 AM
