Old April 21st, 2009, 11:31 AM
mikey chalupa is on a distinguished road
Default Kenmore Elite 110.60972990 No Heat
Ok. my problem is that my motor spins but there is no heat. I also have an issue with my PTS switch. My motor turns whenever I close my door, even if i don't press the PTS. It will stop when the timer get to the off position. It is a new PTS switch. I have replaced the therma fuse. I checked the heating element. it has continuity. The heating element has volage present as does the thermal cut off. The thermal cut off fuse does also. I check votage on the relays. The heating relay has good 48VDC on the terminals. The motor has it on all except one that has 12VDC. also, my motor relay sparked the last time i tried to run it after changing the heater relay which i thought was my original prob. (I ran the dryer in the even heat mode when I got this spark) My question is where should I look now? It's getting expensive just replacing random parts. Is it the even heat board? Would that cause my motor to run constantly without pressing the PTS? Should I get another motor relay even though the resistance on the coil is good? Please help the clothes are piling up!!!
Old April 21st, 2009, 06:47 PM
Thats almost impossible that you put a new PTS(Push-to-start) switch in and it still starts on its own without you pressing the PTS. Where did you purchase the new PTS switch at?
Do an ohm test for continuity on that new PTS switch, take the wires off first of course, with the dryer unplugged. You shouldn't have any continuity on that PTS switch until you push the button on it.
Did you check the continuity on your thermal cut-off as well?
It sounds like your control board may be the issue:
Manufacturer's Number: W10116564
icon
icon
icon
Old April 21st, 2009, 07:09 PM
I got the PTS switch at a Sears Repair store. I originally thought the switch was bad from the store, but i got a replacement and it did the same thing. I did a continuity test on it and it was open, like a should be between the terminals.
I also tested the continuity on the thermal cutoff switch. It read a short, which is correct right? I am starting the suspect the Even heat board. it's really the only thing left.
Old April 21st, 2009, 07:48 PM
The ohms on the thermal cut-off should read 0 or 1 on your ohm meter.
Yes, its likely the control board causing this issue.
Remember only on our site can you shop with confidence as all parts ordered from our site come with a 30 day full refund even if it was installed and didn't fix it.
Kenmore Elite H4 Model # 110-95087 No Heat Bucky Sears Kenmore 17 February 19th, 2009 09:26 AM
[FIXED] Kenmore Elite 110.73932101, no heat jeremycbcd Sears Kenmore 7 July 23rd, 2008 08:16 PM
Even Heat Board Fried in Kenmore Elite 110.73942101 caliamara Sears Kenmore 4 December 10th, 2006 08:55 AM
Kenmore Elite won't heat! Fishbulb Sears Kenmore 1 August 28th, 2006 10:35 AM
Kenmore Elite electric dryer no heat... route62 Sears Kenmore 4 January 10th, 2006 02:40 PM
