Old April 22nd, 2009, 09:15 AM
bearcat401k is on a distinguished road
Default Sears 417.69042991 stays on
Timer will not advance in auto setting, but does advance in timed setting, I have replaced moisture sensor, sensor board, and timer, any Idea's?
Old April 22nd, 2009, 09:44 AM
Thats odd, you've replaced everything that controls the timer movement in the auto-dry setting.
The way the auto-dry works is when your heating element shuts off, then the timer moves, so your heating element is shutting off/cycling in auto-dry?
Old April 22nd, 2009, 03:27 PM
Well what happens ( in auto dry section)is the heater never shuts off and the timer never moves so if you don't watch it it could just run hot all day. But if you put it on the timer side, and let say set the timer for 60 minutes then it will shut off in 60 minutes just fine. It's got me stumbed
Old April 22nd, 2009, 07:23 PM
Ok, then thats tells me that one of your heater element wires has broken and it touching the metal heater housing and causing the heater to always stay on(grounding itself).
You will need to unplug or turn the breaker off to your dryer, then take it apart, this link will show you how:
http://www.applianceaid.com/wwf-howto.html
Then look at your element, you may see a broken element wire TOUCHING the metal housing.
Here's the heating element assembly for your model you can order:
Manufacturer's Number: 131553900
Kenmore overhead freezer leaks - known problem undocumented by Sears iwanano2 Sears Kenmore 3 September 15th, 2007 11:27 AM
Sears the worst company on Earth anubus Appliance Stores & Service Complaints - East of the Mississippi 0 March 7th, 2007 08:46 AM
Sears funny finance Tom Good Appliance Stores & Service Complaints - East of the Mississippi 1 February 7th, 2007 11:55 PM
Sear non-customer service Michael Roder Appliance Stores & Service Complaints - East of the Mississippi 1 September 9th, 2006 11:11 AM
No more Anything from Sears mkothari Sears Kenmore Brand Forum 2 August 5th, 2006 04:32 PM
