I have a Kenmore gas range model number 362.7462101 serial number 3V223073P it is located on a open back porch patio area.It is connected to a extension cord and has been working good forabout the last 2-3 years.It got rained on on the top and control areas,now nothing works and the control board beeps and flashes "bad line" I plugged it into a different plug and it still flashes"bad line" I opened the control panel and checked the power to the control board and it shows good voltage,but nothing works,just flashes "bad line" The control board and insulation pad was very damp.I'm assuming that the control board is bad,what do you guys think?Also is there a wiring diagram or manual available for this range?
Yes Jessie, its a bad control board.
Here's the control board for your model you can order: Manufacturer's Number: WB27K10219 Jake
Thank you,that's what I thought.
Glad to help Jessie.
The control board is supposed to be here today.I have been searching for info and instructions on how to remove the old one and install the new one.Any tips and cautions or help from you guys will be greatly appreciated.Thanks for your help.
Its fairly straight forward, just pull your range out from the wall, unplug your range, then remove the back console panel #106 here:
http://c.searspartsdirect.com/lis_pn...0217-00002.png Then #129 is your control board, it should have 4 screws that mount it in on each of the corners of it. But first mark down on paper where your electrical connections go, then remove the connections to it, then unmount it. The #128 faceplate will likely just peel off the old one, then just put it on the new one. Jake
| Kenmore gas dryer 110.97583210 motor bad..which one is correct replacement? | vermonter | Sears Kenmore | 4 | February 6th, 2009 07:01 PM |
| Gas vs. Electric Range? Here is one more view... | bobl | Maytag/Magic Chef/Admiral/Jenn-Air | 2 | September 9th, 2008 04:00 PM |
| Kenmore gas range - oven burners won't light | squirkie | Sears Kenmore | 3 | November 7th, 2007 08:06 PM |
| Gas Range Model kenmore 790.78739402 | asaood | Sears Kenmore | 1 | August 16th, 2007 08:33 PM |
| kenmore gas range shuts down before reaching set temp | Doug36 | Sears Kenmore | 1 | November 11th, 2006 10:20 PM |
