October 11th, 2005, 06:29 PM
Kenmore Push to Start Problem
Hi
I've been reading the Evenheat problems and solutions in [FIXED] Another Kenmore Dryer problem because my dryer has the same problem. It is a Kenmore 110.73932102, about 3 years old.
The Push to Start button needs to be depressed all the time for the dryer to work. After checking the thread above, I investigated my control board and found the same scorching and leaking capacitors. I replaced it with a new control board from repairclinic.com, but the problem remained.
I read a similar story at Waiting for help - replacing Evenheat board does not solve the Push To Start holding and tried to switch the power/motor relay with the heat relay to see if that solved the problem, but no luck.
I'm open to any ideas or suggestions.
Many thanks
Mike
October 11th, 2005, 11:14 PM
Thats very odd, the control board and the switching the motor/heater relay should have worked, other than that, its either the thermistor or the motor itself.
Also check Jeff1's website link here , this may help you some more:
http://www.applianceaid.com/evenheat.html
If you can't find the problem , its best to call Sears for a tech. to come out.
By knieman in forum Sears Kenmore
Last Post: October 4th, 2006, 11:24 PM
By cefox01 in forum Sears Kenmore
Last Post: April 16th, 2006, 03:53 PM
By Rich in forum Sears Kenmore
Last Post: January 16th, 2006, 11:01 AM
By calif_guy in forum Sears Kenmore
Last Post: September 25th, 2005, 09:53 PM
